HP EliteBook 855 G7 Notebook PC Specifications
Product image
Operating systems
Feature
Pre-installed (Windows)
Windows 10 Pro 64 (National Academic License)
Some devices for academic use automatically update to Windows 10 Pro Education with the Windows 10 Anniversary Update. Features vary.
Windows 10 Pro 64
Windows 10 Enterprise 64 (Volume Licensing Agreement)
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
Pre-installed (other)
FreeDOS 1.2
In accordance with Microsoft support policy, HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Feature
AMD Ryzen 3 PRO 4450U APU with AMD Radeon Graphics
2.5 GHz base clock, up to 3.8 GHz max boost clock
4 MB L3 cache
4 cores
AMD Ryzen 5 PRO 4650U APU with AMD Radeon Graphics
2.1 GHz base clock, up to 4.0 GHz max boost clock
8 MB L3 cache
6 cores
AMD Ryzen 7 PRO 4750U APU with AMD Radeon Graphics
1.7 GHz base clock, up to 4.2 GHz max boost clock
8 MB L3 cache
8 cores
Integrated with processor
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. AMD numbering is not a measurement of higher performance.
AMD Max Burst frequency performance varies depending on hardware, software and overall system configuration.
Processor speed denotes maximum performance mode; processors run at lower speeds in battery optimization mode.
Memory
Feature
Standard
DDR4-PC4 SODIMMS
Supports dual-channel memory
System runs at 3200 MT/s
(2) Dual-channel SODIMM slots (both slots are customer accessible/upgradable)
Configurations
32 GB DDR4-3200 SDRAM (2 x 16 GB)
24 GB DDR4-3200 SDRAM (16 GB (1 x 16 GB) and 8 GB (1 x 8 GB))
20 GB DDR4-3200 SDRAM (16 GB (1 x 16 GB) and 4 GB (1 x 4 GB))
16 GB DDR4-3200 SDRAM (1 x 16 GB)
16 GB DDR4-3200 SDRAM (2 x 8 GB)
12 GB DDR4-3200 SDRAM (8 GB (1 x 8 GB) and 4 GB (1 x 4 GB))
8 GB DDR4-3200 SDRAM (1 x 8 GB)
8 GB DDR4-3200 SDRAM (2 x 4 GB)
4 GB DDR4-3200 SDRAM (1 x 4 GB)
Maximum
32 GB
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Graphics
Feature
Integrated
AMD Radeon Graphics
High-definition (HD) content is required to view high definition images.
Supported
HD decode, DX12, and HDMI 2.0
Feature
Non-touch display
​39.62 cm (15.6 in) diagonal FHD IPS eDP anti-glare WLED-backlit bent, 250 nits, 45% NTSC (1920 x 1080)
​39.62 cm (15.6 in) diagonal FHD IPS eDP anti-glare WLED-backlit bent, 250 nits, 45% NTSC for HD camera (1920 x 1080)
​39.62 cm (15.6 in) diagonal FHD IPS eDP anti-glare WLED-backlit bent, 250 nits, 45% NTSC for HD and IR camera (1920 x 1080)
​39.62 cm (15.6 in) diagonal FHD IPS eDP anti-glare WLED-backlit bent, 250 nits, 45% NTSC for WWAN (1920 x 1080)
​39.62 cm (15.6 in) diagonal FHD IPS eDP anti-glare WLED-backlit bent, 250 nits, 45% NTSC for HD camera for WWAN (1920 x 1080)
​39.62 cm (15.6 in) diagonal FHD IPS eDP anti-glare WLED-backlit bent, 250 nits, 45% NTSC for HD and IR camera for WWAN (1920 x 1080)
​39.62 cm (15.6 in) diagonal FHD IPS eDP and PSR anti-glare WLED-backlit bent, 400 nits, 72% NTSC with Ambient Light Sensor and HD and IR camera with Low Power (1920 x 1080)
​39.62 cm (15.6 in) diagonal FHD IPS eDP and PSR anti-glare WLED-backlit bent, 400 nits, 72% NTSC with Ambient Light Sensor and HD and IR camera for WWAN with Low Power (1920 x 1080)
​39.62 cm (15.6 in) diagonal FHD IPS eDP and PSR anti-glare WLED-backlit bent, 1000 nits with Sure View Reflect, 72% NTSC with Ambient Light Sensor and HD and IR camera (1920 x 1080)
​39.62 cm (15.6 in) diagonal FHD IPS eDP and PSR anti-glare WLED-backlit bent, 1000 nits Sure View Reflect, 72% NTSC with Ambient Light Sensor and HD and IR camera for WWAN (1920 x 1080)
HP Sure View integrated privacy screen is an optional feature that must be configured at purchase and is designed to function in landscape orientation.
Touch display
​39.62 cm (15.6 in) diagonal FHD IPS eDP anti-glare On-Cell WLED-backlit bent touchscreen, 250 nits, 45% NTSC with HD and IR camera (1920 x 1080)
​39.62 cm (15.6 in) diagonal FHD IPS eDP anti-glare On-Cell WLED-backlit bent touchscreen, 250 nits, 45% NTSC, for HD and IR camera for WWAN (1920 x 1080)
HDMI 2.0
Supports resolutions up to 4K at 60 Hz
Resolutions are dependent upon monitor capability and resolution and color depth settings.
Storage/drives
Feature
Primary M.2 Solid State Drive storage
128 GB M.2 SATA TLC SSD
256 GB PCIe NVMe M.2 Value OPAL 2 SED SSD
256 GB PCIe NVMe M.2 TLC SSD
512 GB PCIe NVMe M.2 Value OPAL 2 SED SSD
512 GB PCIe NVMe M.2 TLC SSD
1 TB PCIe NVMe M.2 TLC SSD
256 GB PCIe NVMe Value SSD
512 GB PCIe NVMe Value SSD
For solid state drives or hard drives, GB = 1 billion bytes; TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10) is reserved for system recovery software.
Networking/communication
Feature
Wireless LAN (WLAN)
Intel AX200 Wi-Fi 6 (2x2) and Bluetooth 5 Combo, non-vPro (supporting gigabit file transfer speeds)
Realtek RTL8822BE 802.11ac (2x2) and Bluetooth 5 Combo
Wi-Fi 6 is backwards compatible with prior 802.11 specs.
Wireless access point and internet service is required and is not included. Availability of public wireless access points limited. The specifications for the 802.11 WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11 WLAN devices.
WWAN
Intel XMM 7360 LTE-Advanced Cat 9
WWAN module is an optional feature, requires factory configuration and requires separately purchased service contract. Check with service provider for coverage and availability in your area. Connection speeds might vary due to location, environment, network conditions, and other factors. 4G LTE not available on all products, in all countries/regions.
NFC
NXP NPC300 Near Field Communication Module
Miracast
Yes
Ports/slots
Feature
Ports
(2) USB 3.1 Gen 2 Type-C connector (Alt mode)
(2) USB 3.1 Gen 1 ports (1 charging)
(1) Headphone/microphone combo jack
(1) AC power port
(1) HDMI 2.0 (cable sold separately)
Slots
(1) SIM card slot (not accessible without WWAN)
(1) Smartcard reader (optional)
(1) Nano security lock slot (lock sold separately)
Audio/multimedia
Feature
Audio
Audio by Bang & Olufsen
Integrated 3 multi-array microphone
(2) Integrated stereo speakers
Camera (sold separately)
720p HD camera
720p HD and IR camera (sold separately and internet access required)
Sensors
Ambient light sensor (select models only)
Hall Sensor
Keyboards/pointing devices/function keys
Feature
HP Premium keyboard
Spill-resistant with drain
Optional backlit function and DuraKeys
Backlit keyboard is an optional feature that must be configured at purchase.
Pointing device
Clickpad with multi-touch gesture support
Taps enabled as default
Microsoft Precision Touchpad default gestures support
Function keys
Function keys
F1 – Display switching
F2 – Blank or Privacy (with LED)
F3 – Brightness down
F4 – Brightness up
F5 – Audio mute
F6 – Volume down
F7 – Volume up
F8 – Microphone mute
F9 – Blank or backlight toggle
F10 – Insert
F11 – Airplane Mode
F12 – HP Programmable Key
Print Screen
Power Button (with LED)
Hidden functions
Fn + R - Break
Fn + S - System Rq
Fn + C - Scroll Lock
Fn + E - Insert
Fn + W - Pause
Software/security
Feature
BIOS
HP BIOSphere Gen5 (available on select platforms with 8th generation processors)
HP Sure Start Gen5 (available on select platforms with 8th generation processors)
BIOS Update via Network
Power On Authentication
Master Boot Record Security
Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Pre-boot Authentication
Absolute Persistence Module
Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
Communication/connectivity
HP Connection Optimizer
HP Value add software
HP Hotkey Support
HP Image Assistant
HP Jumpstart
HP Support Assistant (requires Windows and internet access)
HP Noise Cancellation software
Microsoft products
Buy Office (sold separately)
Manageability
HP Driver packs (available for download)
HP System Software Manager (SSM) (available for download)
HP BIOS Configuration Utility (BCU) (available for download)
HP Client Catalog (available for download)
Ivanti Management Suite
HP Client Management Script Library (available for download)
HP Management Integration Kit Gen4 (available for download)
For more information about manageability software, go to the HP Client Management Solutions webpage.
Security
HP Client Security Manager Gen6 (requires Windows and available on select platforms)
HP Fingerprint Sensor (sold separately or as an optional feature)
Microsoft Defender (opt in and internet connection required for updates)
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Common Criteria EAL4+ Certified
Other standard security features
Serial, USB enable/disable (via BIOS)
Power-on password (via BIOS)
Setup password (via BIOS)
HP Sure Click (available on select HP platforms and supports Internet Explorer, Google Chrome, and Chromium)
HP Sure Sense (requires Windows)
Support for chassis padlocks and cable lock devices
Power
Feature
Power supply
Adapters
HP Smart 45 W External AC power adapter
HP Smart 45 W External AC power adapter; 2-prong (Japan only)
HP Smart 65 W External AC power adapter
HP Smart 65 W EM External AC power adapter
65 W USB Type-C adapter
Power cords
3-wire plug - 1 m (3.28 ft)
2-wire plug - 1 m (3.28 ft)
Availability might vary by country/region.
Primary battery
HP Long Life 3-cell, 56 Wh Li-ion
Support HP Fast Charge (up to 50% in 30 minutes with 65 W AC adapter)
Battery is internal and not replaceable by customer. Serviceable by warranty.
Recharges the battery up to 50% within 30 minutes when the system is off or in standby mode. Power adapter with a minimum capacity of 65 Watts is required. After charging has reached 50% capacity, charging returns to normal. Charging time might vary +/-10% due to system tolerance.
Physical specifications
Feature
Touch
Starting at 1.776 kg (3.91 lb)
Non-touch
Starting at 1.696 kg (3.74 lb)
Weight varies by configuration and components.
Dimensions (W x D x H)
Touch
35.94 x 23.67 x 1.98 cm (14.15 x 9.2 x 0.78 in)
Non-touch
35.94 x 23.67 x 1.93 cm (14.15 x 9.2 x 0.76 in)
