    Windows 11 Upgrade Guide
Illustrated parts catalog
Use this table to determine the spare parts that are available for the computer.
Computer major components
To identify the computer major components, use this illustration and table.
HP continually improves and changes product parts. For complete and current information about supported parts for your computer, go to http://partsurfer.hp.com, select your country or region, and then follow the on-screen instructions.
Details about your computer, including model, serial number, product key, and length of warranty, are on the service tag at the bottom of your computer.
Identifying the computer major components
Computer major component descriptions and part numbers
Item
Component
Spare part number
(1)
Display assembly
Display spare parts are available only as subcomponents. For spare part information, see Display assembly subcomponents.
not available as a spare part
(2)
Top cover/keyboard
For a detailed list of country codes, see Keyboard with top cover.
Backlit
M15210-xx1
Not backlit
M15209-xx1
Backlit, for use in privacy models
M15208-xx1
(3)
Touchpad
Without NFC antenna
M07108-001
Includes NFC antenna
M07109-001
(4)
Touchpad button board
M07106-001
(5)
Fingerprint reader
The fingerprint reader cable is available in the Cable Kit as spare part number M07101-001.
M07206-001
(6)
RTC battery
L13694-001
(7)
NFC module
The NFC module cable is available in the Cable Kit as spare part number M07101-001.
M07214-001
(8)
Speakers (left and right)
M07107-001
(9)
USB board
The USB board cable is available in the Cable Kit as spare part number M07101-001.
M27456-001
(10)
System board (includes integrated processor)
All system board spare part kits include replacement thermal material.
All system boards use the following part numbers:
xxxxxx-001: Non-Windows operating systems
xxxxxx-601: Windows operating system
AMD Ryzen 7 PRO 4750U
M22244-xx1
AMD Ryzen 5 PRO 4650U
M22243-xx1
AMD Ryzen 3 PRO 4450U
M22242-xx1
(11)
Card reader board
The card reader board cable is available in the Cable Kit as spare part number M07101-001.
M07105-001
(12)
Power connector cable
M15626-001
(13)
System board bracket (available in Plastics Kit)
M07215-001
(14)
WLAN module
Intel Wi-Fi 6 AX200 + Bluetooth 5 (non-vPro)
L35282-001
Realtek RTL8822CE 802.11ac 2 × 2 Wi-Fi + Bluetooth 5
L44796-001
(15)
Fan
M07102-001
(16)
Heat sink (includes replacement thermal material)
M07204-001
(17)
Solid-state drive
1 TB, PCIe, TLC
L85348-001
512 GB, PCIe, TLC
L85360-001
512 GB, PCIe, TLC, self-encrypting drive (SED)
L85368-001
512 GB, PCIe, value
L85364-001
256 GB, PCIe, TLC
L85350-001
256 GB, PCIe, TLC, self-encrypting drive (SED)
M07245-001
256 GB, PCIe, value
L85354-001
128 GB, SATA-3, TLC
L85346-001
(18)
Solid-state drive cover (included in Bracket Kit)
M08556-001
(19)
Memory modules (DDR4, PC-3200)
16 GB
L67710-001
8 GB
L46598-001
4 GB
L83673-001
(20)
Memory cover (included in Bracket Kit)
M08556-001
(21)
WWAN module
Intel XMM 7360 LTE-Advanced (Cat 9)
L70670-005
(22)
Battery (3 cell, 53 Whr)
L78555-005
(23)
Bottom cover
M15211-001
To identify the display assembly subcomponents, use this illustration and table.
Identifying the display subcomponents
Display component descriptions and part numbers
Item
Component
Spare part number
(1)
Bezel
For use in models with an IR camera and ambient light sensor
M07163-001
M07164-001
For use in models with an RGB camera and ambient light sensor
M07165-001
M07166-001
For use in models with a microphone module (no camera)
M07100-001
(2)
Display panel
1000 nits, ambient light sensor
M08711-001
250 nits, models with WWAN
M07092-001
250 nits, models without WWAN, IR camera, Touch-on Panel (TOP)
M07094-001
400 nits, models without WWAN, IR camera, ambient light sensor
M07093-001
LCD Support Kit (not illustrated)
M25066-001
(3)
Hinge cover (included in Hinge Kit)
M07104-001
(4)
Camera module
RGB camera
M07216-001
IR camera
M08549-001
(5)
Camera cable (included in Cable Kit)
M07101-001
(6)
WLAN antennas and cables
(7)
WWAN antennas and cables
(8)
Ambient light sensor
M07212-001
(9)
Ambient light sensor board to hub board cable (included in Cable Kit)
M07101-001
(10)
Microphone module
M07208-001
Third microphone module
M07209-001
(11)
Microphone board cable (included in Cable Kit)
M07101-001
(12)
Hub board
For use in models with an RGB camera or microphone module
M07210-001
M07211-001
(13)
Display cable (included in Display Cable Kit)
M07203-001
(14)
M07203-001
(15)
Hinges (left and right)
M07104-001
(16)
Display back cover
Models with WWAN, 400 nit panel
M07099-001
Models without WWAN, 400 nit panel
M07097-001
Models without WWAN, 250 nit panel
M07096-001
Models with WWAN, 250 nit panel
M07098-001
Second ambient light sensor (not illustrated)
M07213-001
Second ambient light sensor to display panel cable (included in Cable Kit; not illustrated)
M07101-001
Second ambient light sensor to hub board cable (included in Cable Kit; not illustrated)
M07101-001
Cable Kit
To identify the contents of the Cable Kit, use this table.
Cable Kit content descriptions and part number
Component
Spare part number
Cable Kit, includes:
M07101-001
Hub board to system board cable
Third microphone board to hub board cable
IR camera to hub board cable
Ambient light sensor to hub board cable
Ambient light sensor to hub board cable (privacy models with WWAN)
Ambient light sensor to display panel (privacy models with WWAN)
Dual ambient light sensor to hub board cable
Dual ambient light sensor to display panel cable
Touchpad cable
Fingerprint reader board cable
Smart card reader to system board cable
NFC module to system board cable
USB board to system board cable
Camera/microphone module to hub board cable
Bracket Kit
To identify the Bracket Kit components, use this illustration and table.
Identifying Bracket Kit components
Bracket Kit component descriptions and part numbers
Item
Component
Spare part number
Bracket Kit, includes:
M08556-001
(1)
Memory cover
(2)
(3)
USB bracket
(4)
Fingerprint reader bracket
SIM tray (not illustrated)
Plastics Kit
To identify the Plastics Kit components, use this illustration and table.
Identifying the Plastics Kit components
Plastics Kit component descriptions and part numbers
Item
Component
Spare part number
Plastics Kit, includes:
M07215-001
(1)
I/O frame
(2)
Fingerprint reader insert
(3)
SIM card insert
(4)
Smart card reader insert
WWAN insulator (not illustrated)
Miscellaneous parts
To identify the miscellaneous parts, use this table.
Miscellaneous part descriptions and part numbers
Component
Spare part number
AC adapters
230 W, PFC slim, 7.4 mm
925141-850
65 W, nPFC, SMART, 3 pin, 4.5 mm
710412-001
65 W, nPFC, SMART, 4.5 mm, EM
913691-850
65 W, nPFC, USB-C, straight, 1.8 m
L04650-850
65 W, nPFC, USB-C, RC, 1.8 m
L32392-001
65 W, nPFC, USB-C, 1.8 m
L67440-001
65 W, nPFC, USB-C, travel adapter
L21487-001
45 W, nPFC, SMART, RC, 4.5 mm, nonslim
741727-001
45 W, nPFC, SMART, RC, 4.5 mm, 2 pin
742436-001
Screw Kit
M07205-001
Case
Top load case
679921-001
Backpack
679923-001
HP Prelude Pro 15.6 Backpack
M03617-001
HP Slim Ultrabook Top Load Case
747078-001
Dock
HP Thunderbolt Dock 120 W (with cable)
L15809-001
HP USB-C Dock (with cable)
L64086-001
HP USB-C/A Universal Dock (with cable)
L64087-001
HP USB-C Mini Dock
935327-001
HP Thunderbolt® 0.7m combo cable
L15938-002
Stereo USB headset
840340-001
USB-C-to-RJ-45 adapter
855560-001
USB-C-to-USB-A hub
916838-001
Cable, USB-C (male) to USB-C (male) (1 m)
L65253-001
Lock
HP nano lock
918431-001
HP Sure Key Cable Lock
L65088-001
Mouse
HP USB laser
674318-001
HP Comfort Grip Wireless Mouse
691922-001
HP USB Travel Mouse
757770-001
HP Bluetooth Travel Mouse
L62043-001
Power adapter, duckhead, C5NS
South Korea
L50818-001
North America
L50818-002
Japan
L33157-001
Power cord (C7, conventional, 1.0 m)
Japan
L19375-001
Power cord (C5, conventional, 1.0 m)
Argentina
L19357-001
Australia
L19358-001
Brazil
L19359-001
Denmark
L19360-001
Europe (Austria, Belgium, Finland, France, Germany, the Netherlands, Norway, and Sweden)
L19361-001
India
L19363-001
Israel
L19362-001
Italy
L19364-001
Japan
L19365-001
North America
L19367-001
People's Republic of China
L19368-001
South Africa
L19369-001
South Korea
L19366-001
Switzerland
L19370-001
Taiwan
L19372-001
Thailand
L19371-001
The United Kingdom
L19373-001
Power cord (C5, conventional, 1.8 m)
Argentina
L19357-002
Australia
L19358-002
Brazil
L19359-002
Denmark
L19360-002
L19361-002
India
L19363-002
Israel
L19362-002
Italy
L19364-002
Japan
L19365-002
North America
L19367-002
L19368-002
South Africa
L19369-002
South Korea
L19366-002
Switzerland
L19370-002
Taiwan
L19372-002
Thailand
L19371-002
The United Kingdom
L19373-002
Power cord (C13, premium, 1.0 m)
Argentina
L32029-001
Australia
100661-021
Brazil
L32030-001
Denmark
130627-014
100614-016
India
403440-008
Israel
398062-011
Italy
L32031-001
Japan
653326-005
North America
121565-023
286496-024
South Africa
187487-012
South Korea
231216-015
Switzerland
150304-015
Taiwan
393312-008
United Kingdom
100613-021
Power cord (C5, 1.0 m, premium)
Argentina
L30811-001
Australia
L22327-001
Brazil
L30812-001
Denmark
L22322-001
L22321-001
India
L22624-001
Israel
L22323-001
Italy
L30813-001
Japan
L22330-001
North America
L22319-001
L21930-001
920689-014
South Africa
L22325-001
South Korea
L22328-001
Switzerland
L22324-001
Taiwan
L22329-001
Thailand
L22326-001
United Kingdom
L22320-001
Power cord (C5, fixed duckhead, premium, 1.0 m)
Argentina
L36815-001
Australia
L36816-001
Brazil
L44789-001
Denmark
L36817-001
L36818-001
India
L36820-001
Israel
L36819-001
Italy
L44788-001
North America
L36822-001
L36823-001
South Africa
L36824-001
Switzerland
L36825-001
Taiwan
L36827-001
Thailand
L36826-001
United Kingdom
L36828-001
