1U6D1EA
HP Pavilion - 15-ec1021ns
AMD Ryzen™ 7 4800H (2.9 GHz base clock, up to 4.2 GHz max boost clock, 8 MB L3 cache, 8 cores)
AMD Integrated SoC
16 GB DDR4-3200 SDRAM (2 x 8 GB)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD SVA anti-glare micro-edge WLED-backlit, 220 nits, 45% NTSC (1920 x 1080)
Realtek RTL8822CE 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 5 combo
1 SuperSpeed USB Type-C® 5Gbps signaling rate; 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 USB 2.0 Type-A (HP Sleep and Charge); 1 HDMI 2.0; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
36 x 25.7 x 2.35 cm
Starting at 1.98 kg
150 W Smart AC power adapter
3-cell, 52.5 Wh Li-ion
Battery life mixed usage
Up to 8 hours and 15 minutes
Video Playback Battery life
Up to 11 hours
HP TrueVision 720p HD camera with integrated dual array digital microphone
Audio by B&O; Dual speakers; HP Audio Boost
- ${title}
- ${title}
- ${title}
- ${title}
HP Pavilion - 15-ec1021ns Product Specifications
FreeDOS
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
