    Apache Log4j Update
HP Pavilion Gaming Laptop - 16-a0001ne Product Specifications
1V2C1EA
Intel® Core™ i7-10750H (2.6 GHz base frequency, up to 5 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 6 cores)
Intel® HM470
16 GB DDR4-2933 SDRAM (2 x 8 GB)
Video graphics
NVIDIA® GeForce® GTX 1650 Ti (4 GB GDDR6 dedicated)
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
40.9 cm (16.1") diagonal, FHD (1920 x 1080), IPS, micro-edge, anti-glare, 250 nits, 45% NTSC
Realtek 802.11 b/g/n/ac (2x2) and Bluetooth® 5 combo
1 SuperSpeed USB Type-C® 5Gbps signaling rate (DisplayPort™ 1.4); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 2.0; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
37 x 26.25 x 2.35 cm
Starting at 2.35 kg
150 W Smart AC power adapter
3-cell, 52.5 Wh Li-ion
Battery life mixed usage
Up to 4 hours and 45 minutes
Video Playback Battery life
Up to 5 hours and 45 minutes
HP TrueVision 720p HD camera with integrated dual array digital microphone
Audio by B&O; Dual speakers; HP Audio Boost 1.0
FreeDOS
