1U3B0EA
HP Spectre x360 Laptop - 15-eb0036na
Intel® Core™ i7-10750H (2.6 GHz base frequency, up to 5 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 6 cores)
Intel® HM370
16 GB DDR4-2666 SDRAM (onboard)
Video graphics
NVIDIA® GeForce® GTX 1650 Ti with Max-Q design (4 GB GDDR6 dedicated)
1 TB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal 4K UHD, UWVA, BrightView, micro-edge, AMOLED, multitouch-enabled, edge-to-edge glass with anti-reflection Corning® Gorilla® Glass NBT™, 400 nits, 100% DCI-P3 (3840 x 2160)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
2 Thunderbolt™ 3 (40Gbps signaling rate) with SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 HDMI 2.0b; 1 SuperSpeed USB Type-A 10Gbps signaling rate (HP Sleep and Charge); 1 headphone/microphone combo
35.99 x 22.64 x 1.99 cm
Starting at 1.92 kg
135 W Smart AC power adapter
6-cell, 72.9 Wh Li-ion polymer
Battery life mixed usage
Up to 6 hours and 45 minutes
Video Playback Battery life
Up to 7 hours and 45 minutes
HP True Vision 720p HD IR camera with integrated dual array digital microphone
Audio by Bang & Olufsen, quad speakers, HP Audio Boost 2.0
- ${title}
- ${title}
- ${title}
- ${title}
HP Spectre x360 Laptop - 15-eb0036na Product Specifications
HP 3D DriveGuard; HP Audio Switch; HP Command Center; HP JumpStart; HP Support Assistant
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
