1S7U6EA
HP Laptop - 14s-fq0800ng
AMD Ryzen™ 3 3250U (2.6 GHz base clock, up to 3.5 GHz max boost clock, 1 MB L2 cache, 2 cores)
AMD Integrated SoC
8 GB DDR4-2400 SDRAM (2 x 4 GB)
Video graphics
AMD Radeon™ Graphics
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
35.6 cm (14") diagonal FHD, SVA, anti-glare, micro-edge, WLED-backlit, 220 nits, 45% NTSC (1920 x 1080)
Intel® Wi-Fi 6 AX 200 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
32.4 x 22.5 x 1.79 cm
1.46 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 7 hours and 30 minutes
Video Playback Battery life
Up to 8 hours and 45 minutes
HP True Vision 720p HD camera with integrated dual array digital microphone
Dual speakers
- ${title}
- ${title}
- ${title}
- ${title}
HP Laptop - 14s-fq0800ng Product Specifications
Pre-installed software
Alexa; Netflix; ExpressVPN (30 day free trial)
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
