1P8F7EA
HP Laptop - 15s-eq0024nw
AMD Athlon™ 300U (2.4 GHz base clock, up to 3.3 GHz max boost clock, 4 MB L3 cache, 2 cores)
AMD Integrated SoC
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
AMD Radeon™ Vega 3 Graphics
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), micro-edge, anti-glare, 220 nits, 45% NTSC
Realtek 802.11 b/g/n/ac (2x2) and Bluetooth® 5 combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo
35.85 x 24.2 x 1.79 cm
1.74 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers
- ${title}
- ${title}
- ${title}
- ${title}
HP Laptop - 15s-eq0024nw Product Specifications
Pre-installed software
Netflix
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
