Product Specifications for the HP DeskJet Ink Advantage 2337 All-in-One Printer (7WQ07B)
Product naming
Model name
7WQ07B
What's included and accessories
What's in the box
HP DeskJet Ink Advantage 2337 Printer; HP 682 Setup Black Cartridge; HP 682 Setup Tri-color Cartridge; Regulatory flyer; Setup guide; Reference guide; Power cord [For ink volume and page yield information, visit http://hp.com/go/learnaboutsupplies]
Accessories
None
Connectivity
Ports
1 Hi-Speed USB 2.0
Wireless capability
No
Storage device and direct print support
Storage devices not supported
Copy
Copier settings
Auto-enlarge
Color copy capability
Yes
Maximum number of copies
Up to 9 copies
Copy resolution
Up to 600 x 300 dpi
Environmental
Acoustic power emissions (active, printing)
6.2 B(A)
Acoustic pressure emissions
48 dB(A)
Recommended operating humidity range
20 to 80% RH
Non-Operating Humidity Range
5 to 90% RH (non-condensing)
Recommended operating temperature range (Celsius)
15 to 30°C
Recommended operating temperature range (Fahrenheit)
59 to 86°F
Storage temperature range (Celsius)
-40 to 60°C
Storage temperature range (Fahrenheit)
-40 to 140°F
Environmental specifications
None
Memory
Memory
Integrated memory
Maximum Memory
Integrated memory
Mobile printing capability
Mobile printing services
Mobile Print Capability not supported
Paper handling
Input capacity
Up to 60 sheets
Standard input capacity (cards)
Up to 20 cards
Standard input capacity (envelopes)
Up to 5
Output capacity
Up to 25 sheets
Media sizes supported (metric)
A4; B5; A6; DL envelope
Media sizes supported (U.S. standard)
Letter; legal; 4 x 6 in; 5 x 7 in; 8 x 10 in; No. 10 envelopes
Media sizes, custom (metric)
89 x 127 to 215 x 279 mm
Media sizes, custom (U.S. standard)
3 x 5 to 8.5 x 14 in
Media types
Plain paper, Photo paper, Brochure paper
Media weight supported (metric)
A4: 60 to 90 g/m²; HP envelopes: 75 to 90 g/m²; HP cards: up to 200 g/m²; HP 10 x 15 cm photo paper: up to 300 g/m²
Media weight supported (U.S. standard)
20 lb
Borderless printing
No
Physical dimensions
Maximum dimensions (W x D x H, metric)
425.2 x 304.1 x 149.1 mm
Maximum dimensions (W x D x H, U.S. standard)
16.47 x 11.97 x 5.87 in
Weight (metric)
3.42 kg
Weight (U.S. standard)
7.55 lb
Power
Energy savings feature technology
HP Auto-Off Technology
Internal
Power supply
Input voltage: 100 to 240 VAC (+/- 10%), 50/60 Hz (+/- 3 Hz). Input voltage: 200 to 240 VAC (+/- 10%), 50/60 Hz (+/- 3Hz) (China & India)
Power consumption
0.05 watts (Off), 1.83 watts (Ready), 0.83 watt (Sleep), 0.05 watts (Auto-off)
Print cartridges
Number of print cartridges
2 (1 each black, tri-color)
Replacement cartridges
EMEA: HP 653 Tri-color Original Ink Advantage Cartridge (~200 pages yield) 3YM74AE; HP 653 Black Original Ink Advantage Cartridge (~360 pages yield) 3YM75AE. APJ: HP 682 Tri-color Original Ink Advantage Cartridge (~150 pages yield) 3YM76AA; HP 682 Black Original Ink Advantage Cartridge (~480 pages yield) 3YM77AA. LAR: HP 667 Tri-color Original Ink Advantage Cartridge (~100 pages yield) 3YM78AL; HP 667 Black Original Ink Advantage Cartridge (~120 pages yield) 3YM79AL; HP 667XL Black High-Yield Original Ink Advantage Cartridge (~480 pages yield) 3YM81AL; HP 667XL Tri-Color High-Yield Original Ink Advantage Cartridge (~330 pages yield) 3YM80AL; HP 667 Tri-color Original Ink Advantage Cartridge (~100 pages yield) 3YM78AB; HP 667 Black Original Ink Advantage Cartridge (~120 pages yield) 3YM79AB; HP 667XL Black High-Yield Original Ink Advantage Cartridge (~480 pages yield) 3YM81AB; HP 667XL Tri-Color High-Yield Original Ink Advantage Cartridge (~330 pages yield) 3YM80AB. Actual yield varies considerably based on content of printed pages and other factors. For details see http://www.hp.com/go/learnaboutsupplies
Printing specifications
Print technology
HP Thermal Inkjet
Duplex printing
Manual (driver support provided)
Print speed black (ISO)
Up to 7.5 ppm
Print speed color (ISO)
Up to 5.5 ppm
Print resolution (best)
Up to 4800 x 1200 optimized dpi color (when printing from a computer on selected HP photo papers and 1200 input dpi)
Maximum print area (metric)
216 x 355 mm
Monthly duty cycle
Up to 1000 pages
Print languages
HP PCL 3 GUI
Printer smart software features
Manual Duplex
Regulatory specifications
Regulatory model number
SNPRH-1504-01
Energy efficiency
CECP; SEPA
Safety
IEC 60950-1:2005 +A1:2009 +A2:2013, EN 60950-1:2006 +A11:2009 +A1:2010 +A12:2011 +A2:2013, EN 62479:2010; Nemko certified, China (CCC), Russia (EAC), CSA Canada certified, Singapore SPRING, EU LVD compliant
Electromagnetic compatibility
EN 55032:2015 / CISPR 32:2015 Class B, EN 55024:2010 / CISPR 24:2010, EN 55035:2017 / CISPR 35:2016, EN 61000-3-2:2014 / IEC 61000-3-2:2014, EN 61000-3-3:2013 / IEC 61000-3-3:2013, FCC CFR 47 Part 15 Class B, ICES-003, Issue 6 Class B; GB4943.1-2011 (CCC -China), CNS 14336: 1999 & CNS13438 (BSMI-Taiwan), VCCI-2 (Japan) & EAC (Russia)
Scan
Scan technology
Contact Image Sensor (CIS)
Scan resolution, hardware
Up to 1200 x 1200 dpi
Levels of grayscale
256
Bit depth
24-bit
Maximum flatbed scan size (metric)
216 x 297 mm
Maximum flatbed scan size (U.S. standard)
8.5 x 11.69 in
Twain version
Version 2.1
System requirements
Minimum system requirements for Windows
Windows 10, 7: 1 GHz 32-bit (x86) or 64-bit (x64) processor, 2 GB available hard disk space, Internet connection, USB port, Internet Explorer
Recommended system requirements for Windows
One-year limited hardware warranty; 24-hour, 7 days a week support
