    Fix HP Printer issue on macOS
HP V20 HD+ Monitor Product Specifications
Panel
1H848AA
Display panel type
TN
19.5"
Panel active area (W x H)
432 x 239.76 mm
Resolution
HD+ (1600 x 900)
Aspect ratio
16:9
Brightness (typical)
200 nits
Contrast ratio (typical)
600:1 static
Response times
5ms on/off
Pixel pitch
0.27 mm
Display features
Anti-glare; Low blue light mode
Onscreen controls
User controls
Brightness; Contrast; Exit; Information; Management; Power; Image; Color
Resolutions supported
Signal interface/performance
1024 x 768; 1280 x 1024; 1280 x 720; 1280 x 800; 1366 x 768; 1440 x 900; 1600 x 900; 640 x 480; 720 x 400; 800 x 600
Video/other inputs/cables
Interface
HDMI; VGA
Display Input Type
1 VGA; 1 HDMI 1.4
Ergonomics
VESA mount
100 mm x 100 mm (bracket included)
Physical security
Security lock-ready
Power
Input voltage
Input voltage 100 to 240 VAC
Power consumption
16 W (maximum), 15 W (typical), 0.3 W (standby)
Physical specifications
Dimensions With Stand (W x D x H)
46.26 x 19 x 35.36 cm
Dimensions (W x D x H)
46.26 x 4.92 x 27.87 cm
18.21 x 1.94 x 10.97 in
Product dimensions with stand (W x D x H)
18.21 x 7.48 x 13.92 in
2.81 kg
What's in the box
What's in the box
Monitor; AC power cord; Documentation; VGA cable; QSP
Environmental
Operating temperature range (deg C)
5 to 35°C
Operating temperature range (deg F)
41 to 95°F
Operating humidity range
20 to 80% RH
Certifications and compliances
Australian-New Zealand MEPS; BIS; BSMI; CB; CCC; CE; CEL; cTUVus; EAC; Energy Star; ErP; E-standby; FCC; ICES; KC/KCC; Mexico CoC; MSIP; PSB; RCM; S-Mark; TCO Certified; VCCI; Vietnam MEPS; WEEE; ISC; South Africa Energy; ISO 9001; TUS-GS; EC1062; HDMI/DP Certification; WW application
