HP ZBook Firefly 14 G7 Mobile Workstation Specifications
Product image
Feature
Preinstalled (Windows)
Windows 10 Pro 64 (recommended by HP)
Windows 10 Enterprise 64
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software, or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Preinstalled (other)
FreeDOS 1.2
Processors
Feature
Intel Core i7-10810U Processor
1.1 GHz, up to 4.9 GHz with Intel Turbo Boost technology
12 MB cache, 6 cores
Supports Intel vPro technology
Intel UHD Graphics
Intel Core i7-10710U Processor
1.1 GHz, up to 4.7 GHz with Intel Turbo Boost technology
Intel UHD Graphics
Intel Core i7-10610U Processor
1.8 GHz, up to 4.9 GHz with Intel Turbo Boost technology
8 MB cache, 4 cores
Intel UHD Graphics
Intel Core i7-10510U Processor
8 MB cache, 4 cores
Intel UHD Graphics
Intel Core i5-10310U Processor
1.7 GHz, up to 4.4 GHz with Intel Turbo Boost technology
6 MB cache, 4 cores
Intel UHD Graphics
Intel Core i5-10210U Processor
1.6 GHz, up to 4.2 GHz with Intel Turbo Boost technology
6 MB cache, 4 cores
Intel UHD Graphics
Integrated with processor
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Processor speed denotes maximum performance mode; processors run at lower speeds in battery optimization mode.
Graphics
Feature
Integrated
Intel UHD Graphics
Ultra High-definition (UHD) content is required to view ultra high definition images.
Discrete
NVIDIA P520 (4 GB GDDR5 dedicated)
Supports
HD decode
DirectX 12
HDMI 1.4 and HDCP 2.3 via DisplayPort up to 4K at 60 Hz and via HDMI up to 4K at 30 Hz
Multi-display support (UMA and discrete configurations)
With HP Thunderbolt Dock G2
Supports three independent displays
Maximum resolutions
2.5K at 60 Hz (DisplayPort 1) and 2.5K at 60 Hz (DisplayPort 2) and FHD (VGA)
Or
4K at 60 Hz (one DisplayPort port) and 4K at 60 Hz (Type-C output port using a Type-C to DP adapter)
With HP UltraSlim Dock
Maximum resolutions
Feature
Touch display
35.56 cm (14.0 in) diagonal FHD IPS eDP touchscreen 45% NTSC at 250 nits (1920 x 1080)
Non-touch display (optional)
35.56 cm (14.0 in) FHD IPS eDP and PSR anti-glare, 100% sRGB at 400 nits with ambient light sensor (1920 x 1080)
35.56 cm (14.0 in) diagonal FHD IPS eDP anti-glare, 45% NTSC at 250 nits (1920 x 1080)
35.56 cm (14.0 in) diagonal 4K UHD HDR-400 IPS eDP 1.4 and PSR anti-glare, 95% sRGB, 550 nits with ambient light sensor (3840 x 2160)
35.56 cm (14.0 in) diagonal with HP SureView Reflect Integrated Privacy Display, FHD IPS eDP and PSR anti-glare, 72% NTSC at 1000 nits (1920 x 1080)
HP Sure View Reflect integrated privacy screen is an optional feature that must be configured at purchase.
Supported display resolutions
High-definition (HD) content is required to view high definition images.
Resolutions are dependent upon monitor capability, and resolution and color depth settings.
Memory
Feature
Standard
Without discrete graphics
(2) SODIMMs
Supports dual-channel memory
With discrete graphics
Memory soldered down
Soldered down memory is a requirement on configurations that have discrete graphics.
Maximum
64 GB DDR4-3200 non-ECC SDRAM
64 GB memory configurations is only available on configurations without discrete graphics.
32 GB DDR4-3200 non-ECC SDRAM
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Storage/drives
Feature
Primary M.2 Solid State Drive storage
256 GB PCIe Gen 3 x4 NVMe M.2 2280 TLC Self Encrypting (SED) SSD
512 GB PCIe Gen 3 x4 NVMe M.2 2280 TLC Self Encrypting (SED) SSD
256 GB PCIe Gen 3 x4 NVMe M.2 2280 TLC SSD
512 GB PCIe Gen 3 x4 NVMe M.2 2280 TLC SSD
1 TB PCIe Gen 3 x4 NVMe M.2 2280 TLC SSD
2 TB PCIe Gen 3 x4 NVMe M.2 2280 TLC SSD
256 GB PCIe Gen 3 x4 NVMe M.2 2280 TLC Value SSD
128 GB PCIe Gen 3 x2 NVMe M.2 2280 TLC SSD
512 GB PCIe Gen 3 x4 NVMe M.2 2280 QLC SSD with 32 GB Intel Optane Memory
For solid state drives or hard drives, GB = 1 billion bytes. TB = 1 trillion bytes. Actual formatted capacity is less. Up to 35 GB (for Windows 10) is reserved for system recovery software.
Networking/communication
Feature
Wireless LAN (WLAN)
Intel Wi-Fi 6 AX201 (2x2) and Bluetooth 5 combo, vPro
Intel Wi-Fi 6 AX201 (2x2) and Bluetooth 5 combo, non-vPro
Wi-Fi 6 is backwards compatible with prior 802.11 specs.
Wireless access point and Internet service is required and is not included. Availability of public wireless access points limited. The specifications for the 802.11 WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11 WLAN devices.
WWAN
Intel XMM 7560 LTE-Advanced Pro Cat 16
Gigabit class Category 16 4G LTE module is optional and must be configured at the factory. Module designed for up to 1 Gbps download speeds as carriers deploy 5 carrier aggregation and 100 Mhz channel bandwidth, requires activation and separately purchased service contract. Backwards compatible to HSPA 3G technologies. Connection, upload and download speeds varies due to network, location, environment, network conditions, and other factors.
4G LTE not available on all products, in all countries/regions.
Intel XMM 7360 LTE-Advanced Cat 9
Near Field Communication (NFC) module
Optional
Miracast support
Yes
Ports/slots
Feature
Ports
(2) USB 3.2 Type-C ports with Thunderbolt support (40 Gbps signaling rate with SuperSpeed USB Type-C 10 Gbps signaling rate (USB Power Delivery, DisplayPort 1.2, HP Sleep and Charge)
(2) USB 3.2 Gen 1 Type-A ports (1 charging)
(1) HDMI 2.0 (cable sold separately)
(1) Headphone/microphone combo jack
(1) AC power input port
Slot
(1) Nano SIM card slot
All units have a SIM card stray but units that do not support WWAN are shipped with a non-removable SIM slot plug.
(1) Smartcard reader (optional)
(1) Nano security lock slot (lock sold separately)
Audio/multimedia
Feature
Audio
Audio by Bang & Olufsen
HP World Facing Microphone multi-array digital microphone
HD audio
Camera (sold separately or as an optional feature)
720p HD webcam
720p HD and IR webcam
HD content required to view HD images.
Windows Hello face authentication utilizes a camera specially configured for near infrared (IR) imaging to authenticate and unlock Windows devices as well as unlock your Microsoft Passport.
Keyboard/pointing device
Feature
HP Premium keyboard
Spill resistant and full-size
DuraKeys
Clickpad with image sensor and glass surface, multitouch gestures and taps enabled
Optional backlit keyboard
Pointing device
Dual pointstick
Glass clickpad with multi-touch gestures enabled (taps enabled as default) and image sensor
Microsoft Precision Touchpad default gestures supported
Software/security
Feature
BIOS
HP BIOSphere Gen6 (available on select platforms)
HP Sure Start Gen6
BIOS Update via Network
HP PC Hardware Diagnostics UEFI
HP PC Hardware Diagnostics Windows
Power On Authentication
Master Boot Record Security
HP Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Pre-boot Authentication
Absolute Persistence Module
Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
Communication/connectivity
HP Connection Optimizer
HP Value add software
HP Mobile Connect Pro (only available on preconfigured devices with WWAN)
Not available in all countries/regions.
HP Sure Recover Gen3 (requires internet connection and not for systems with multiple drives)
HP Sure Recover with Embedded Reimaging Gen3 (requires internet connection and not for systems with multiple drives)
HP Hotkey Support
HP Performance Advisor (download only)
HP Recovery Manager
HP Sure Sense (requires Windows)
HP ZCentral Remote Boost Software (download only)
HP Image Assistant
HP Device Access Manager
HP Support Assistant (requires Windows and internet access)
HP Noise Cancellation software
HP QuickDrop
HP Touchpoint Customizer
HP WorkWell
myHP
HP Sure Platform (for platforms with discrete graphics)
Microsoft products
Buy Office (sold separately)
Skype for Business Certified (not available in China)
Manageability
HP Driver packs (available for download)
HP Management Integration Kit Gen4 for Microsoft SCCM (available for download)
For more information about manageability software, go to the HP Client Management Solutions webpage.
Security
HP Client Security Manager Gen6 (requires Windows and available on select platforms)
HP Fingerprint Sensor (sold separately or as an optional feature)
Windows Defender (opt in and internet connection required for updates)
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Common Criteria EAL4+ Certified
Power
Feature
Power adapters
HP Smart 45 W External AC power adapter (not available with discrete graphics configurations)
HP Smart 65 W External AC power adapter
Availability might vary by country/region.
Primary battery
HP Long Life 3-cell, 53 Wh Li-ion
Supports fast charging
Recharges the battery up to 50% within 30 minutes when the system is off or in standby mode. Power adapter with a minimum capacity of 65 Watts is required. After charging reaches 50% capacity, charging returns to normal. Charging time might vary +/-10% due to system tolerance.
Battery life
Up to 23 hours
Battery life varies depending on the product model, configuration, loaded applications, features, use, wireless functionality and power management settings. The maximum capacity of the battery naturally decreases with time and usage.
Weight/dimensions
Specification
Starting at 1.34 kg (2.95 lb)
Weight varies by configuration and components.
Dimensions (W x D x H)
32.36 x 21.46 x 1.80 cm (12.74 x 8.45 x 0.71 in)
