    Apache Log4j Update
HP Laptop - 15s-du2017tx Product Specifications
160T0PA
Intel® Core™ i5-1035G1 (1.0 GHz base frequency, up to 3.6 GHz with Intel® Turbo Boost Technology, 6 MB L3 cache, 4 cores)
4 GB DDR4-2666 SDRAM (1 x 4 GB)
256 GB PCIe® NVMe™ M.2 SSD
15.6" diagonal FHD SVA anti-glare micro-edge WLED-backlit, 220 nits, 45% NTSC (1920 x 1080)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 SuperSpeed USB Type-C® 5Gbps signaling rate; 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 1.4b; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
35.85 x 24.2 x 1.99 cm
Starting at 1.75 kg
65 W Smart AC power adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD camera with integrated dual array digital microphone
Dual speakers
HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer
