    Find Windows 11 and Windows 10 support help. Visit Windows Support Center
     Connect with HP support faster, manage all of your devices in one place, view warranty information and more. Sign up for an HP account
HP V22 FHD Monitor Product Specifications
9SV79AA
Display size
21.5"
Display type
TN
Panel active area(inches)
18.77 x 10.56 in
Panel active area(cms)
476.64 x 268.11 mm
Brightness
250 nits
Pixel Pitch
0.248 mm
Input connector
1 VGA; 1 HDMI 1.4
Scan range (horizontal)
30-80 KHz
Scan range (vertical)
50-60 Hz
Recommended resolution
1920 x 1080 (FHD)
Aspect ratio
16:9
Static contrast ratio;Dynamic contrast ratio
1000:1 static
Response time
5ms on/off
Power consumption
19 W (maximum), 18.5 W (typical), 0.5 W (standby)
Power supply
Input voltage 100 to 240 VAC
Dimensions
50.5 x 42 x 31.02 cm
2.85 kg
