9RV16AA
Display size
23.8"
Display type
IPS
Panel active area(inches)
20.75 x 11.67 in
Panel active area(cms)
527.04 x 296.46 mm
Brightness
250 nits
Pixel Pitch
0.274 mm
Input connector
1 VGA; 1 HDMI 1.4 (with HDCP support)
Scan range (horizontal)
30-80 KHz
Scan range (vertical)
50-60 Hz
Recommended resolution
1920 x 1080 (FHD)
Aspect ratio
16:9
Static contrast ratio;Dynamic contrast ratio
1000:1 static
Response time
5ms GtG
Power consumption
26 W (maximum), 23.5 W (typical), 0.5 W (standby)
Power supply
Input voltage 100 to 240 VAC
Dimensions
53.96 x 4.76 x 32.5 cm
3.46 kg
- ${title}
- ${title}
- ${title}
- ${title}
HP V24i FHD Monitor Product Specifications
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
