HP Pavilion Gaming Laptop - 15-dk1190ng Product Specifications
1B2D5EA
Intel® Core™ i7-10750H (2.6 GHz base frequency, up to 5 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 6 cores)
Intel® HM470
32 GB DDR4-2933 SDRAM (2 x 16 GB)
Video graphics
  • Intel® UHD Graphics
  • Discrete
  • NVIDIA® GeForce RTX™ 2060 with Max-Q design (6 GB GDDR6 dedicated)
1 TB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD, 144 Hz, IPS, anti-glare, micro-edge, WLED-backlit, 300 nits, 72% NTSC (1920 x 1080)
Realtek 802.11 b/g/n/ac (2x2) and Bluetooth® 5 combo
1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 2.0; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
36 x 25.6 x 2.34 cm
Starting at 2.23 kg
200 W Smart AC power adapter
3-cell, 52.5 Wh Li-ion
HP Wide Vision 720p HD camera with integrated dual array digital microphone
Audio by B&O; Dual speakers; HP Audio Boost 1.0
FreeDOS
