    Windows 11 Upgrade Guide
HP Pavilion Gaming Laptop - 15-dk1006tx Product Specifications
154X3PA
Intel® Core™ i7-10750H (2.6 GHz base frequency, up to 5 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 6 cores)
Intel® HM470
16 GB DDR4-2933 SDRAM (1 x 16 GB)
1 TB PCIe® NVMe™ M.2 SSD
15.6" diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 2.0; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
36 x 25.6 x 2.34 cm
Starting at 2.23 kg
200 W Smart AC power adapter
3-cell, 52.5 Wh Li-ion
HP Wide Vision HD camera with integrated dual array digital microphone
Audio by B&O; Dual speakers; HP Audio Boost 1.0
HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; OMEN Command Center; HP Connection Optimizer; HP PC Hardware Diagnostics Windows
Pre-installed software
ExpressVPN (30 day free trial); iQiyi; LastPass password manager (30 day free trial)
