Product Specifications for the HP DeskJet Plus Ink Advantage 6075 All-in-One Printer (5SE22C)
Product naming
Model name
5SE22C
What's included and accessories
What's in the box
HP DeskJet Plus Ink Advantage 6075 All-in-One Printer; HP 653 Setup Black Cartridge; HP 653 Setup Tri-Color Cartridge; Regulatory flyer; Setup guide; Reference guide; Power cord. For ink volume and page yield information, visit http://www.hp.com/go/learnaboutsupplies
Connectivity
Ports
1 Hi-Speed USB 2.0; 1 Wi-Fi 802.11ac (dual band)
Wireless capability
Yes, built-in Wi-Fi 802.11b/g/n
Copy
Copier settings
Colour, monochrome
Color copy capability
Yes
Maximum number of copies
Up to 9 copies
Copy reduce / enlarge settings
25 to 200%
Copy resolution
Up to 300 x 300 dpi
Environmental
Acoustic power emissions (active, printing)
6.7 B(A)
Acoustic pressure emissions
56 dB(A) (printing at 5 ppm)
Recommended operating humidity range
25 to 75% RH (non-condensing)
Non-Operating Humidity Range
20 to 80% RH (non-condensing)
Recommended operating temperature range (Celsius)
15 to 30°C
Storage temperature range (Celsius)
-40 to 60°C
Fax
Fax available
No
Mobile printing capability
Mobile printing services
HP Smart app; Apple AirPrint™; Mopria™-certified
Paper handling
Input capacity
Up to 100 sheets
Standard input capacity (cards)
Up to 40 cards
Output capacity
Up to 25 sheets
Media sizes supported (metric)
A4; A5; B5; DL; C6; A6
Media sizes, custom (metric)
Simplex: 76.2 x 127 mm to 216 x 297 mm; Duplex: 76.2 x 127 mm to 216 x 297 mm
Media types
Plain Paper; HP Photo Papers; HP Matte Brochure or Professional Paper; HP Matte Presentation Paper; HP Glossy Brochure or Professional Paper; Other Photo Inkjet Papers; Other Matte Inkjet Papers; Other Glossy Inkjet Papers; Plain Paper, Light/Recycled
Media weight supported (metric)
A4: 60 to 90 g/m²; HP envelopes: 75 to 90 g/m²; HP cards: up to 200 g/m²; HP 10 x 15 cm photo paper: up to 300 g/m²
Borderless printing
Yes (up to 8.5 x 11 in, 216 x 297 mm)
Physical dimensions
Maximum dimensions (W x D x H, metric)
432.5 x 511.5 x 132.1 mm
Weight (metric)
5.22 kg
Power
Built-in Universal Power Supply
Power supply
Input voltage: 220 to 240 VAC (+/- 10%), 50/60 Hz, 0.7A
Power consumption
0.10 Watts (off) , 4.0 Watts (ready) , 1.70 Watts (sleep)
Print cartridges
Number of print cartridges
2 (1 each black, tri-color)
Replacement cartridges
3YM74AL HP 653 Tri-color Original Ink Advantage Cartridge (~200 pages yield); 3YM75AL HP 653 Black Original Ink Advantage Cartridge (~360 pages yield); 3YM76AE HP 682 Tri-color Original Ink Advantage Cartridge (~150 pages yield); 3YM77AE HP 682 Black Original Ink Advantage Cartridge (~480 pages yield); 3YM78AE HP 667 Tri-color Original Ink Advantage Cartridge (~100 pages yield); 3YM79AA HP 667 Black Original Ink Advantage Cartridge (~120 pages yield); 3YM81AA HP 667XL Black High-Yield Original Ink Advantage Cartridge (~480 pages yield); 3YM80AA HP 667XL Tri-Color High-Yield Original Ink Advantage Cartridge (~330 pages yield)
Printing specifications
Print technology
HP Thermal Inkjet
Duplex printing
Automatic (standard)
Print speed black (ISO)
Up to 10 ppm
Print speed color (ISO)
Up to 7 ppm
Print resolution (best)
Up to 1200 x 1200 rendered dpi (when printing from a computer)
Monthly duty cycle
Up to 1000 pages
Print languages
HP PCL 3 GUI
Scan
Scan technology
CIS
Scan resolution, hardware
Up to 1200 x 1200 dpi
Levels of grayscale
256
Bit depth
24-bit
Maximum flatbed scan size (metric)
215.9 x 297 mm
Twain version
Version 2.1
System requirements
Minimum system requirements for Windows
Windows 10, 7: 1 GHz 32-bit (x86) or 64-bit (x64) processor, 2 GB available hard disk space, Internet connection, USB port, Internet Explorer
Recommended system requirements for Windows
Minimum System Requirements for Macintosh
MacOS Sierra v10.12 (previously OS X), macOS High Sierra v10.13, macOS Mojave v10.14, macOS Catalina v10.15, 2 GB available hard disk space, Internet Access.
Recommended Macintosh system requirements
Compatible Network Operating Systems
Windows 10, 7; MacOS Sierra v10.12 (previously OS X), macOS High Sierra v10.13, macOS Mojave v10.14, macOS Catalina v10.15
One-year limited hardware warranty; 24-hour, 7 days a week support
