3G432UA
HP ENVY Laptop - 13-ba0085nr
Intel® Core™ i7-10510U (1.8 GHz base frequency, up to 4.9 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
16 GB DDR4-3200 SDRAM (onboard)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
13.3" diagonal FHD, IPS, BrightView, micro-edge, WLED-backlit, multitouch-enabled, edge-to-edge glass, 400 nits, 100% sRGB (1920 x 1080)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.2, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 AC smart pin; 1 headphone/microphone combo
30.65 x 19.46 x 1.69 cm
1.3 kg
65 W Smart AC power adapter
3-cell, 51 Wh Li-ion
HP Wide Vision HD camera with camera shutter and integrated dual array digital microphone
Audio by Bang & Olufsen; Dual speakers
- ${title}
- ${title}
- ${title}
- ${title}
HP ENVY Laptop - 13-ba0085nr Product Specifications
HP Connection Optimizer; HP Audio Switch; HP BIOS Protection; HP Command Center; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix; Biometric Fingerprint Reader
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
