9GB29UA
HP Spectre x360 Laptop - 15-eb0043dx
Intel® Core™ i7-10510U (1.8 GHz base frequency, up to 4.9 GHz with Intel® Turbo Boost Technology, 8 MB L3 cache, 4 cores)
16 GB DDR4-2933 SDRAM (onboard)
Video graphics
Intel® UHD Graphics
512 GB Intel® SSD
Optical drive
Optical drive not included
15.6" diagonal 4K UHD, IPS, micro-edge, WLED-backlit, multitouch-enabled, edge-to-edge glass with anti-reflection Corning® Gorilla® Glass NBT™, 340 nits, 72% NTSC (3840 x 2160)
Intel® Wi-Fi 6 AX 201 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
1 Thunderbolt™ 3 (40Gbps signaling rate) with SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.2, HP Sleep and Charge); 1 SuperSpeed USB Type-C® 10Gbps signaling rate (USB Power Delivery, DisplayPort™ 1.2, HP Sleep and Charge); 1 HDMI 2.0a; 1 SuperSpeed USB Type-A 10Gbps signaling rate (HP Sleep and Charge); 1 AC smart pin; 1 headphone/microphone combo
35.99 x 22.64 x 1.99 cm
2.04 kg
90 W Smart AC power adapter
6-cell, 72.9 Wh Li-ion polymer
Battery life mixed usage
Up to 13 hours and 30 minutes
Video Playback Battery life
Up to 16 hours and 30 minutes
HP TrueVision HD IR camera with integrated dual array digital microphone
Audio by Bang & Olufsen; Quad speakers
- ${title}
- ${title}
- ${title}
- ${title}
HP Spectre x360 Laptop - 15-eb0043dx Product Specifications
HP Connection Optimizer; HP Audio Switch; HP BIOS Protection; HP Command Center; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix; Alexa; Biometric Fingerprint Reader
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Thailand
- ${title}
hp-hero-support-search
- ${title}
