HP Spectre x360 - 15-df1021na Product Specifications
7WA13EA
Intel® Core™ i7-9750H (2.6 GHz base frequency, up to 4.5 GHz base with Intel® Turbo Boost Technology, 12 MB cache, 6 cores)
Intel® Integrated SoC
16 GB DDR4-2666 SDRAM (onboard)
Video graphics
NVIDIA® GeForce® GTX 1650 Graphics (4 GB GDDR5 dedicated)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass with Corning® Gorilla® Glass NBT™ and HP Sure View, 650 nits, 72% NTSC (1920 x 1080)
Intel® Wi-Fi 6 AX 200 (2x2) and Bluetooth® 5 Combo (Supporting Gigabit file transfer speeds)
1 microSD media card reader
2 USB 3.1 Gen 2 Type-C™ with Thunderbolt™ 3 (40 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.4, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 1 AC smart pin; 1 HDMI 2.0b; 1 headphone/microphone combo
36.12 x 25 x 1.93 cm
Starting at 2.09 kg
135 W Smart AC power adapter
6-cell, 84 Wh Li-ion polymer
Battery life mixed usage
Up to 15 hours and 45 minutes
Video Playback Battery life
Up to 14 hours and 30 minutes
Audio by Bang & Olufsen; Quad speakers; HP Audio Boost 2.0
HP 3D DriveGuard; HP Audio Switch; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix
