    Windows 11 Upgrade Guide
HP ProBook 445 G7 Notebook PC Specifications
Product image
HP ProBook 450 G7 Notebook PC
Operating systems
Feature
Preinstalled (Windows)
Windows 10 Pro 64 (National Academic License)
Some devices for academic use automatically update to Windows 10 Pro Education with the Windows 10 Anniversary Update. Features vary.
Windows 10 Pro 64
Windows 10 Enterprise 64 (Web support)
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, software or BIOS update to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
Preinstalled (other)
FreeDOS 1.2
In accordance with Microsoft support policy, HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel and AMD 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Processors
Feature
AMD Ryzen 3 4300U APU with AMD Radeon Graphics
2.7 GHz base clock, up to 3.7 GHz max boost clock
4 MB L3 cache
4 cores
AMD Ryzen 5 4500U APU with AMD Radeon Graphics
2.3 GHz base clock, up to 4.0 GHz max boost clock
8 MB L3 cache
6 cores
AMD Ryzen 7 4700U APU with AMD Radeon Graphics
2.0 GHz base clock, up to 4.1 GHz max boost clock
8 MB L3 cache
8 cores
Integrated with processor
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. AMD numbering is not a measurement of higher performance.
AMD Max Burst frequency performance varies depending on hardware, software and overall system configuration.
Processor speed denotes maximum performance mode; processors run at lower speeds in battery optimization mode.
Graphics
Feature
Integrated
AMD Radeon Graphics
Supported
HD decode, DX12, and HDMI 1.4
High-definition (HD) content is required to view high definition images.
Feature
Non-touch display
35.56 cm (14.0 in) diagonal HD SVA eDP anti-glare LED backlit slim, 220 cd/m², 45% NTSC (1366 x 768)
35.56 cm (14.0 in) diagonal HD SVA eDP anti-glare LED backlit slim, 220 cd/m², 45% NTSC for HD camera (1366 x 768)
35.56 cm (14.0 in) diagonal HD SVA eDP anti-glare LED backlit slim, 220 cd/m², 45% NTSC for HD and IR camera (1366 x 768)
35.56 cm (14.0 in) diagonal FHD IPS eDP anti-glare LED-backlit slim, 250 cd/m², 45% NTSC (1920 x 1080)
35.56 cm (14.0 in) diagonal FHD IPS eDP anti-glare LED-backlit slim, 250 cd/m², 45% NTSC for HD camera (1920 x 1080)
35.56 cm (14.0 in) diagonal FHD IPS eDP anti-glare LED-backlit slim, 250 cd/m², 45% NTSC for HD and IR camera (1920 x 1080)
35.56 cm (14.0 in) diagonal FHD eDP and PSR anti-glare LED-backlit flat, 1000 cd/m², 72% NTSC for HD Webcam Privacy (1920 x 1080)
Supports narrow bezel.
HDMI 1.4
Supports resolutions up to 4K at 30 Hz
Resolutions are dependent upon monitor capability and resolution and color depth settings.
HP Sure View integrated privacy screen is an optional feature that must be configured at purchase and is designed to function in landscape orientation.
Storage/drives
Feature
Primary M.2 Solid State Drive storage
128 GB M.2 SATA TLC SSD
256 GB PCIe NVMe M.2 Value SSD
512 GB PCIe NVMe M.2 TLC SSD
512 GB PCIe NVMe M.2 Value SSD
Primary SATA hard drives
500 GB 7200 RPM
1 TB 5400 RPM
For solid state drives or hard drives, GB = 1 billion bytes; TB = 1 trillion bytes. Actual formatted capacity is less. Up to 30 GB (for Windows 10) is reserved for system recovery software.
Memory
Feature
Standard
DDR4-PC4 SODIMMS
Supports dual-channel memory
(2) Dual-channel SODIMM slots (both slots are customer accessible/upgradable)
Configurations
32 GB DDR4-3200 SDRAM (16 GB x 2)
16 GB DDR4-3200 SDRAM (8 GB x 2)
16 GB DDR4-3200 SDRAM (16 GB x 1)
12 GB DDR4-3200 SDRAM (8 GB x 1 and 4 GB x 1)
8 GB DDR4-3200 SDRAM (8 GB x 1)
8 GB DDR4-3200 SDRAM (4 GB x 2)
4 GB DDR4-3200 SDRAM (4 GB x 1)
Maximum
32 GB
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Ports/slots
Feature
Ports
(1) USB 3.1 Type-C Gen 1 connector (Power Delivery, DisplayPort)
(2) USB 3.1 Gen 1
(1) USB 2.0 (Powered port)
(1) RJ-45
(1) Headphone/microphone combo jack
(1) AC power port
(1) HDMI 1.4
HDMI cable sold separately.
Slot
(1) Standard security lock
(1) SD Card reader (supports SD, SDHC, and SDXC)
Networking/communication
Feature
Wireless LAN (WLAN)
Intel Dual Band Wireless-AC 9260 802.11ac (2x2) Wi-Fi and Bluetooth 5 Combo, non-vPro
Intel Dual Band Wi-Fi 6 AX200 802.11ax (2x2) and Bluetooth 5 Combo, non-vPro
Realtek RTL8822CE 802.11ac (2x2) Wi-Fi and Bluetooth 5 Combo
Wireless access point and internet service is required and is not included. Availability of public wireless access points limited. The specifications for the 802.11 WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the notebook to communicate with other 802.11 WLAN devices.
Ethernet
Realtek RTL8111EP 10/100/1000 GbE NIC
The term "10/100/1000" or "Gigabit" Ethernet indicates compatibility with IEEE standard 802.3ab for Gigabit Ethernet, and does not connote actual operating speed of 1 Gb/s. For high-speed transmission, connection to a Gigabit Ethernet server and network infrastructure is required.
Audio/multimedia
Feature
Audio
Integrated microphone (mono or dual-array)
(2) Integrated stereo speakers
Speaker power
2 W/4 ohm per speaker
Camera
720p HD camera
720p HD and IR camera (sold separately)
Keyboards/pointing devices/function keys
Feature
HP Premium keyboard
Spill-resistant with optional backlit function
Backlit keyboard is an optional feature that must be configured at purchase.
Pointing device
Clickpad with multi-touch gesture support
Function keys
Function keys
F1 – Display switching
F2 – Blank or SureView On/Off
F3 – Brightness down
F4 – Brightness up
F5 – Audio mute
F6 – Volume down
F7 – Volume up
F8 – Microphone mute
F9 – Blank or backlight toggle
F10 – Num lock
F11 – Wi-Fi toggle
F12 – Sleep
Hidden functions
Fn + R - Break
Fn + S - System Rq
Fn + C - Scroll Lock
Software/security
Feature
BIOS
HP BIOSphere Gen5 (available on select platforms with 8th generation processors)
HP Sure Start Gen5 (available on select platforms with 8th generation processors)
BIOS Update via Network
Power On Authentication
Master Boot Record Security
Secure Erase (methods outlined in the National Institute of Standards and Technology Special Publication 800-88)
Pre-boot Authentication
Absolute Persistence Module
Absolute agent is activated when customers activate a purchased subscription. Subscriptions can be purchased for terms ranging multiple years. Service is limited, check with Absolute for availability outside the U.S. The Absolute Recovery Guarantee is a limited warranty. Certain conditions apply. Data Delete is an optional service provided by Absolute Software. If utilized, the Recovery Guarantee is null and void. In order to use the Data Delete service, customers must first sign a Pre-Authorization Agreement and either obtain a PIN or purchase one or more RSA SecurID tokens from Absolute Software.
Communication/connectivity
HP Connection Optimizer
HP Value add software
HP Hotkey Support
HP Image Assistant
HP Jumpstart
HP Support Assistant (requires Windows and internet access)
HP Noise Cancellation software
Microsoft products
Buy Office (sold separately)
Manageability
HP Driver packs (available for download)
HP System Software Manager (SSM) (available for download)
HP BIOS Configuration Utility (BCU) (available for download)
HP Client Catalog (available for download)
HP Management Integration Kit Gen3 for Microsoft SCCM (available for download)
For more information about manageability software, go to the HP Client Management Solutions webpage.
Security
HP Client Security Manager Gen5 (requires Windows and available on select platforms)
HP Fingerprint Sensor (sold separately or as an optional feature)
Microsoft Defender (opt in and internet connection required for updates)
For Windows 10, Trusted Platform Module (TPM) 2.0 (Infineon SLB9670)
Common Criteria EAL4+ Certified
Other standard security features
Serial, USB enable/disable (via BIOS)
Power-on password (via BIOS)
Setup password (via BIOS)
HP Sure Click (available on select HP platforms and supports Internet Explorer, Google Chrome, and Chromium)
HP Sure Sense (requires Windows)
Support for chassis padlocks and cable lock devices
Power
Feature
Power supply
Adapters
HP Smart 65 W External AC power adapter
HP Smart 65 W EM External AC power adapter
HP Smart 65 W USB Type-C adapter
HP Smart 45 W External AC power adapter
HP Smart 45 W USB Type-C adapter
Power cords
3-wire plug - 1 m (3.28 ft)
3-wire plug - 1.8 m (5.9 ft)
2-wire plug - 1 m (3.28 ft)
Duckhead power cord - 1 m (3.28 ft)
Duckhead power cord - 1.8 m (5.9 ft)
Availability might vary by country/region.
Primary battery
HP Long Life 3-cell, 45 Wh Li-ion
Battery is internal and not replaceable by customer. Serviceable by warranty.
Battery weight
0.22 kg (0.49 lb)
Physical specifications
Feature
Starting at 1.6 kg (3.53 lb)
Weight varies by configuration and components.
Dimensions (W x D x H)
32.41 x 23.77 x 1.80 cm (12.76 x 9.36 x 0.71 in)
