    Fix HP Printer issue on macOS
HP Pavilion - 15-cs3035nb Product Specifications
9YL24EA
Intel® Core™ i5-1035G1 (1.0 GHz base frequency, up to 3.6 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
  • 256 GB PCIe® NVMe™ M.2 SSD
  • 1 TB 5400 rpm SATA
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS anti-glare micro-edge WLED-backlit, 250 nits, 45% NTSC (1920 x 1080)
Realtek Wi-Fi 5 (2x2) and Bluetooth® 5 combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo; 1 RJ-45
36.16 x 24.56 x 1.79 cm
Starting at 1.85 kg
65 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 8 hours and 30 minutes
Video Playback Battery life
Audio by B&O; Dual speakers; HP Audio Boost
