HP ScanJet Pro 2000 s2, 3000 s4, N4000 snw1 / HP ScanJet Enterprise Flow 5000 s5, 7000 s3, N7000 snw1 - Product specifications
This section introduces the product specifications.
Supported operating systems
The following information applies to the scanner-specific Windows and HP scan drivers for macOS and to the software installer.
Windows: See the software installation notes for more information.
macOS: Mac computers are supported with this scanner. Download the software from the product support home page, and then use it to install the HP scan driver.
  1. Go to the product support home page.
  2. Follow the steps provided to download the scanner software.
Linux: For information and scan drivers for Linux, go to www.hp.com/go/linuxprinting.
For a current list of supported operating systems, go to the product support home page for HP's all-inclusive help for the scanner:
Minimum system requirements
Windows 10, 8.1, 7
macOS Catalina v10.15, macOS Mojave v10.14, macOS High Sierra v10.13
Mobile devices, iOS, Android
  • 32-bit or 64-bit
  • 2 GB of available hard disk space
  • Microsoft Internet Explorer
  • Internet connection
  • USB port
Router connection not required
Product dimensions
Make sure your scanner environment is large enough to accommodate the scanner.
Scanner dimensions
Product dimensions
Model
1. Height
2. Depth
3. Width
2000 s2, 3000 s4 and N4000 snw1 models
154 mm
172 mm
300 mm
2.7 kg
5000 s5, 7000 s3 and N7000 snw1 models
190 mm
198 mm
310 mm
4.0 kg
Power consumption, electrical specifications, and acoustic emissions
In order to operate properly, the scanner must be in an environment that meets certain power specifications.
See www.hp.com/support for current information.
Ensure to connect the power cord of power adapter to a socket-outlet with earthing connection.
Power requirements are based on the country/region where the product is sold. Do not convert operating voltages. This will damage the product and void the product warranty.
Operating environmental range
Review the recommended operating-environment specifications for your scanner.
Environment
Recommended
Allowed
Temperature
17.5° to 25°C
10° to 35°C
Relative humidity
30% to 70% relative humidity (RH)
10% to 80% RH
Altitude
Not applicable
0 to 3048 m
