    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Are you working from home?
Document ID: c06587149
Version: 1
HP Engage Go Convertible Systems - Dock Firmware Auto Update Fails With BIOS Version 01.08 or Later
Release date : 05-Mar-2020
Last updated : 10-Mar-2020
DESCRIPTION
The dock firmware update fails with BIOS versions 01.08 to 1.10. The issue occurs if the computer is not docked when the BIOS update is performed.
SCOPE
BIOS:
  • Version 1.08
  • Version 1.09
  • Version 1.10
Systems:
  • HP Engage Go Mobile Systems
  • HP Engage Go Convertible System
RESOLUTION
Avoid the issue by docking the computer prior to updating the BIOS.
Resolve the issue using one of the following options:
Option 1. Dock the computer and reinstall the BIOS.
Option 2. Dock the computer, locate the SoftPaq folder, then run HpFirmwareUpdRec64.exe.
NOTE: The issue will be fixed in a future BIOS version.
Hardware platforms affected : HP Engage Go Convertible System, HP Engage Go Mobile System
Support Communication Cross Reference ID : IA06587149
