    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Microsoft Support for Windows 7 ended on Jan 14, 2020
    - HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
    - If your computer is not compatible for upgrade to Windows 10, we can help to find the perfect computer for you. Check our Weekly deals!
Document ID: c06586355
Version: 1
Final HP Z Workstation Series March 2020 Refresh (Windows 10: 1903) - PSG
Release date : 05-Mar-2020
Last updated : 05-Mar-2020
รายละเอียดการเปลี่ยนแปลง
Effective March 2, 2020, HP is changing the BIOS configuration on HP Z workstations that come with Windows 10. The new software addition and updates are being made available for download from HP’s support Web site for owners of existing Z4 G4, Z6 G4, and Z8 G4 series workstations.
HP Z4 G4 Core-X series workstations BIOS 2.46 has the following enhancements added:
  • Updates UEFI Specification Version to v2.6.
  • Updates Intel RAID Option ROM/Driver to v6.2.0.1034.
  • Updates UEFI-based Hardware Diagnostics to v2.1.2.0.
  • Adds WMI option to allow user to choose system behavior when boot media is not detected.
  • Adds WMI option to configure PCIe MaxReadRequestSize.
  • Adds WMI setting to not reset defaults when RTC power is lost.
  • Fixes an issue where graphics cards with Option ROM disabled would be listed as available in F10.
  • Fixes an issue where system would not exit from IPv6 manual configuration menu in F10.
  • Fixes an issue where PCIe throttling would not work with multiple NVMe devices installed.
HP Z4 G4 series workstations BIOS 2.46 has the following enhancements added:
  • Updates Intel VROC Option ROM/Driver to v6.2.0.1034.
  • Updates Intel TXT SINIT ACM to v1.3.54.
  • Fixes an issue where system would show incorrect FRU hardware information with AMT enabled.
  • Fixes an issue where boot device menu would appear when using ME Setup or Cira during SOL session.
HP Z6 G4 and Z8 G4 series workstations BIOS 2.47 has the following enhancements added:
  • Updates Intel TXT SINIT ACM to v1.7.48.
  • Fixes an issue where devices on SATA ports would operate at 1.5 Gb/s (Z8 G4 only).
REASON FOR CHANGE
N/A.
IMPACT OF CHANGE
Various quality of life fixes and improvements to functionality for all platforms.
Components affected:
Windows 10 Updated components
DATE OF CHANGE
Effective date : 02-Mar-2020
Hardware platforms affected : HP Z4 G4 Workstation, HP Z6 G4 Workstation, HP Z8 G4 Workstation
