    Windows 11 Upgrade Guide
Document ID: c06582558
Version: 1
HP ProBook 4xx G7, Zhan 66 Pro 14, 15 G3 Notebook PCs - Computer Is Experiencing Performance Issues During Windows Updates
Release date : 26-Feb-2020
Last updated : 26-Feb-2020
DESCRIPTION
The computer is experiencing performance issues. Downloading and installing Windows Updates may cause the OS to lag, exhibit slowness, or freeze.
This issue does not only affects the computers listed in the Scope, but any computer that is downloading and installing Windows Updates.
Configuring critical Windows Updates may be displayed.
Configuring crtical Windows Updates screen
SCOPE
The information in this document applies to the following:
Computers:
  • HP ProBook 430 G7 Notebook PC
  • HP ProBook 440 G7 Notebook PC
  • HP ProBook 450 G7 Notebook PC
  • HP ZHAN 66 Pro 14 G3 Notebook PC
  • HP ZHAN 66 Pro 15 G3 Notebook PC
Operating Systems:
Non-OS Specific
RESOLUTION
This is expected behavior. Computer performance may be impacted until the following actions are completed:
Downloading the updates: Windows is in the process of downloading updates. Overall computer performance may be slower until all the updates are downloaded completely.
Installing the updates: Windows is in the process of installing the updates. Overall computer performance may be slower until all updates are installed successfully.
If the computer is experiencing performance issues, it is recommended to download and install all the available updates. The update packages may be large in size, and can impact overall computer performance while downloading and installing the updates.
  1. Click Start, and then select the Settings icon.
  2. Click Update & Security.
  3. Click Windows Update. Windows will check automatically, download and install the updates (if any new updates are available).
Hardware platforms affected : HP ProBook 430 G7 Notebook PC, HP ProBook 440 G7 Notebook PC, HP ProBook 450 G7 Notebook PC, HP ZHAN 66 Pro 14 G3 Notebook PC, HP ZHAN 66 Pro 15 G3 Notebook PC
Support Communication Cross Reference ID : IA06582558
