    Fix Windows 10 Update Issues
    Are you working from home?
Product Specifications for the HP Neverstop Laser 1000n (5HG74A)
Product naming
Model name
5HG74A
Connectivity
Ports
Hi-Speed USB 2.0 port; Fast Ethernet 10/100 Base
Wireless capability
No
Environmental
Acoustic power emissions (active, printing)
6.5 B(A)
Recommended operating humidity range
30 to 70% RH
Recommended operating temperature range (Celsius)
17.5 to 25°C
Storage temperature range (Celsius)
-20 to 50°C
Environmental specifications
Mercury-free
Memory
Memory
32 MB
Maximum Memory
32 MB
Mobile printing capability
Mobile printing services
Apple AirPrint™; Google Cloud Print™; HP Smart App and other mobile Apps; Mopria™ Certified; Wi-Fi® Direct printing
Mobile printing compatibility note
Apple AirPrint: Mobile device must have AirPrint®. Google Cloud Print™ 2.0: Requires Google Cloud Print™ registration and Google account. Learn more at http://www.hp.com/go/mobileprinting.
Paper handling
Input capacity
Up to 150 sheets
Standard input capacity (envelopes)
Up to 1 envelope
Output capacity
Up to 100 sheets
Media sizes supported (metric)
A6; A5; A4; No.10 Env; C5 Env; DL Env; B5(JIS), Oficio 216x340; 105 x 148.5 to 216 x 356 mm
Media sizes, custom (metric)
Media types
Plain paper; Heavy paper; Bond paper; Label; Light paper; Envelope
Media weight supported (metric)
60 to 120 g/m²
Physical dimensions
Maximum dimensions (W x D x H, metric)
380.5 x 465 x 445 mm
Weight (metric)
6.95 kg
Power
Energy savings feature technology
HP Auto-On/Auto-Off Technology
Internal (built-in) Power Supply
Power supply
220V - 240V nominal at +/-10% (min 198V, max 264V), 50 - 60Hz nominal +/- 3Hz (min 47Hz, max 63Hz)
Print cartridges
Number of print cartridges
1 Imaging Drum
Replacement cartridges
HP 103A Black Original Neverstop Laser Toner Reload Kit (2,500 pages); HP 103AD Dual pack Black Original Neverstop Laser Toner Reload Kit (2 x 2,500 pages); HP 104A Black Original Laser Imaging Drum (includes 5,000 pages of in-box toner, useful life of 20,000 pages)
Replacement cartridges footnote
Declared black toner page yield value in accordance with ISO/IEC 19752 and continuous printing. Actual yields vary considerably based on images printed and other factors. For details see http://www.hp.com/go/learnaboutsupplies.
SureSupply note
HP SureSupply alerts you when your print cartridge is running low and helps you purchase online or locally through HP or a participating retailer. For more information, visit http://www.hp.com/go/SureSupply; only available with Original HP supplies; Internet access required.
Printing specifications
Print technology
Laser
Duplex printing
Manual (driver support provided)
Print resolution (best)
Up to 600 x 600 x 2 dpi
Maximum print area (metric)
216 x 355.6 mm
Monthly duty cycle
Up to 20,000 pages
Print languages
PCLmS; URF; PWG
Printer smart software features
Apple AirPrint™, Mopria-certified, HP Auto-On/Auto-Off, HP Smart App, HP Smart Task
Regulatory specifications
Safety
IEC 60950-1:2005+A1:2009+A2:2013 (International); EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013 (EU); IEC/EN 60825-1:2014 (Class 1 Laser Product); EN 62479:2010/IEC 62749:2010; Low Voltage Directive 2006/95/EC with CE Mark (Europe)
Electromagnetic compatibility
EN 61000-3-2:2014, EN 61000-3-3:2013, EN55024:2010, EN 55032:2012/AC:2013, ICES-003 Issue 5, GB/T 9254-2008, GB17625.1-2012, CISPR22:2008, other EMC approvals as required by individual countries
System requirements
Minimum system requirements for Windows
Windows® 10, 8, 7: 32/64-bit, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer
Minimum System Requirements for Macintosh
Apple®OS X EI Capitan (v10.11), macOS Sierra (v10.12), macOS High Sierra (v10.13), 1.5 GB available hard disk space, Internet required, USB
Compatible Network Operating Systems
Windows® 10, 8, 7: 32/64-bit, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer; Apple®OS X EI Capitan (v10.11) macOS Sierra (v10.12) macOS High Sierra, (v10.13), 1.5 GB available hard disk space, Internet required, USB; Linux: for more information, see https://www.developers.hp.com/hp-linux-imaging-and-printing
Operating system (supported note)
Not all "Compatible Operating Systems" are supported with in-box software; Full solution software available only for Windows 7 and newer; For Windows Server 2008 R2 64-bit, 2012 64-bit, 2012 R2 64-bit, 2016 64-bit only print driver is installed. Windows RT OS for Tablets (32/64-bit) uses a simplified HP print driver built into the RT OS; Linux systems use in-OS HPLIP software.
HP one year hardware limited warranty. For full terms and conditions visit: http://www.hp.com/go/orderdocuments.
