    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Are you working from home?
HP PrinterOn Enterprise - Do I need a Mobile print license in Equitrac if I want to send print jobs from PrinterOn and release them from Equitrac?
  • If the PrinterOn Enterprise license is obtained through Nuance/Equitrac, then Mobile print licenses are required in Equitrac.
  • If the PrinterOn Enterprise license is NOT obtained through Nuance/Equitrac, then Mobile print licenses are NOT required in Equitrac.
