    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Are you working from home?
SUPPORT COMMUNICATION- SECURITY BULLETIN
Document ID: c06566323
Version: 2
HPSBHF03654 rev. 2 - HP Wide Vision FHD Camera Firmware Security Update
Notice:: The information in this security bulletin should be acted upon as soon as possible.
Release date : 18-Feb-2020
Last updated : 21-Feb-2020
Potential Security Impact:
Arbitrary Code Execution, Denial of Service
Source: HP, HP Product Security Response Team (PSRT)
Reported by: Rick Altherr of Eclypsium
VULNERABILITY SUMMARY
Potential security vulnerabilities in the HP Wide Vision FHD Camera firmware may allow the ability to update the camera with unsigned firmware.
Reference Number
CVE Pending, PSR-2019-0164
SUPPORTED SOFTWARE VERSIONS*: ONLY impacted versions are listed.
See RESOLUTION section below.
BACKGROUND
For a PGP signed version of this security bulletin please write to: hp-security-alert@hp.com
CVSS 3.0 Base Metrics
Reference
Base vector
Base score
CVE Pending
Pending
Pending
RESOLUTION
HP has identified the affected platforms and target versions for SoftPaqs. See the affected platforms listed below.
HP recommends keeping your system up to date with the latest firmware, drivers, and software.
Sign up for HP Subscriptions and get notifications for:
  • Product support eAlerts
  • Driver updates
  • Security bulletin updates
Verify the firmware version of your HP Wide Vision FHD Camera
Use Windows Device Manager to see if you have an impacted HP Wide Vision FHD Camera firmware for the products listed below.
  1. Search Windows for Device Manager, and then click Device Manager in the list of results.
  2. Double-click Cameras.
    If you see the HP Wide Vision FHD Camera for the listed product in this document, continue these steps.
  3. Double-click the HP Wide Vision FHD Camera product.
  4. Select the Details tab.
  5. In the drop-down menu under Property, select Hardware Ids.
  6. Check the firmware version.
    The camera firmware version can be identified by finding REV_#### within the top value string.
    For example, REV_0004 is the version of the firmware for 0004-C051.
  7. If you have an earlier firmware version than what is listed for your product, update the firmware using the link provided in this document.
Home PCs
Consumer notebook
Product Name
Updated Version
SoftPaq
SoftPaq Link
HP Spectre 13-ap0XXX x360 Convertible PC
0004-C051
SP101659
Third Party Security Patches: Third party security patches that are to be installed on systems running HP software products should be applied in accordance with the customer's patch management policy.
Support: For issues about implementing the recommendations of this Security Bulletin, visit https://www.hp.com/go/contacthp to learn about your HP support options.
Report: To report a potential security vulnerability with any HP supported product, send email to: hp-security-alert@hp.com.
Subscribe: To initiate a subscription to receive future HP Security Bulletin alerts via email, visit https://www.hp.com/go/alerts.
Security Bulletin Archive: To view released Security Bulletins, search the HP Support Site for "security bulletin".
Software Product Category: The Software Product Category is represented in the title by the two characters following HPSB.
PI
HP Printing and Imaging
HF
HP Hardware and Firmware
GN
HP General Software
It is strongly recommended that security related information being communicated to HP be encrypted using PGP, especially exploit information.
To get the security-alert PGP key, please send an e-mail message as follows:
Subject: get key
System management and security procedures must be reviewed frequently to maintain system integrity. HP is continually reviewing and enhancing the security features of software products to provide customers with current secure solutions.
"HP is broadly distributing this Security Bulletin in order to bring to the attention of users of the affected HP products the important security information contained in this Bulletin.HP recommends that all users determine the applicability of this information to their individual situations and take appropriate action.HP does not warrant that this information is necessarily accurate or complete for all user situations and, consequently, HP will not be responsible for any damages resulting from user's use or disregard of the information provided in this Bulletin.To the extent permitted by law, HP disclaims all warranties, either express or implied, including the warranties of merchantability and fitness for a particular purpose, title and non-infringement."
REVISION HISTORY : Version: 1 - 18 February 2020 Initial release. Version: 2 - 21 February 2020 Added instructions to check the firmware versions, and corrected the version and SoftPaq information.
