    Windows 11 Upgrade Guide
Product Specifications for the HP Color LaserJet Pro MFP M283fdn (7KW74A)
Product naming
Model name
7KW74A
What's included and accessories
What's in the box
HP Color LaserJet Pro MFP M283fdn printer; Introductory HP LaserJet cartridges: 700 colour composite (C/Y/M) page yield and 1,350 page yield black; Installation guide; Power cord; Phone cord
Connectivity
Ports
Hi-Speed USB 2.0 port; Built-in Fast Ethernet 10/100/1000 Base-TX network port; Fax port; Front Host USB
Storage device and direct print support
USB Printing; Front-facing USB/Flash drive
Copy
Copier settings
Number of copies; Reduce/Enlarge; Lighter/Darker; Optimize; Paper; Multi-page copy; Collation; Draft Mode; Image Adjustment; Set as New Defaults; Restore Defaults
Maximum number of copies
Up to 99 copies
Copy reduce / enlarge settings
25 to 400%
Copy speed (color, normal)
Up to 21 cpm
Copy speed (black, normal)
Up to 21 cpm
Copy resolution
Up to 600 x 600 dpi
Environmental
Acoustic power emissions (active, printing)
6.4 B(A) (monochrome), Simplex; 6.3 B(A) (colour), Simplex; 6.3 B(A) (monochrome), Duplex; 6.3 B(A) (colour), Duplex
Recommended operating humidity range
30 to 70% RH
Non-Operating Humidity Range
0 to 95% RH
Recommended operating temperature range (Celsius)
15 to 27°C
Storage temperature range (Celsius)
-20 to 40°C
Environmental specifications
Mercury Free
Fax
Fax available
Yes
Fax features
Auto redialing, delayed sending, fax forwarding, TAM interface, distinctive ring detection, cover page wizard (Software only), block fax, billing codes, poll receive, fax activity reports, dial prefix setting
Fax Resolution Black (best)
Up to 300 x 300 dpi
Fax memory
Up to 1300 pages
Telephone handset supported
Yes
Fax telephone mode supported
Yes
Modem
33.6 kbps
Fax Speed Dials, Maximum Number
Up to 120 numbers
Fax transmission speed (letter)
3 sec per page
Memory
Memory
256 MB DDR, 256 MB Flash
Maximum Memory
Mobile printing capability
Mobile printing services
HP ePrint; Apple AirPrint™; Mobile Apps; Mopria™ Certified
Networking
Network protocols, supported
TCP/IP, IPv4, IPv6; Print: TCP-IP port 9100 Direct Mode, LPD (raw queue support only), WSD; Discovery: SLP, Bonjour, WS-Discovery; IP Config: IPv4 (BootP, DHCP, AutoIP, Manual), IPv6
Paper handling
Input capacity
1 sheet in Tray 1; Up to 250 sheets (25 mm stack height) in Tray 2
Output capacity
Up to 100 sheets (10 mm stack height)
Media sizes supported (metric)
Executive (184 x 267 mm); Oficio 8.5x13 (216 x 330 mm); 4 x 6 (102 x 152 mm); 5 x 8 (127 x 203 mm); A4 (210 x 299 mm); A5 (148 x 210 mm); A6 (105 x 148 mm); B5(JIS) (182 x 257 mm); B6(JIS) (128 x 182 mm); 10 x 15cm (100 x 150 mm); Oficio (216 x 340 mm); 16K (195 x 270 mm; 184 x 260 mm; 197 x 273mm); Postcard(JIS) (100 x 147 mm); Double Postcard(JIS) (147 x 200 mm); Envelope #10 (105 x 241 mm); Envelope Monarch (98 x 191 mm); Envelope B5 (176 x 250 mm); Envelope C5 (162 x 229 mm); Envelope DL (110 x 220 mm); A5-R (210 x 148 mm)
Media sizes, custom (metric)
76 x 127 to 216 x 356 mm
Media types
Paper (bond, brochure, coloured, glossy, heavy, letterhead, light, photo, plain, preprinted, prepunched, recycled, rough), transparencies, labels, envelopes, cardstock
Media weight supported (metric)
60 to 163 g/m² (Uncoated/Matte, recommended), however up to 175 g/m² Postcards and 200 g/m² HP Matte is allowed in the driver; 60 to 163 g/m² (Coated/Glossy, recommended), however up to 175 g/m² Postcards and 220 g/m² HP Glossy is allowed in the driver.
Paper handling - ADF
Automatic document feeder capacity
Standard, 50 sheets
Media size (ADF)
A4
Media weight supported, ADF (metric)
60 to 90 g/m²
Media type and capacity, ADF
Sheets: 50 (75 g/m² uncurled)
Paper handling - duplexer
Recommended media weight, duplex (metric)
60 to 120 g/m² (recommended), 60 to 200 g/m² (allowed)
Physical dimensions
Maximum dimensions (W x D x H, metric)
424 x 475 x 338 mm
Weight (metric)
18.7 kg
Power
Energy savings feature technology
HP Auto-On/Auto-Off Technology; Instant-on Technology
Internal (Built-in) power supply
Power supply
220 to 240 VAC (+/- 10%), 50 Hz (+/- 3 Hz), 60 Hz (+/- 3 Hz)
Power consumption
361 watts (active printing), 7.8 watts (ready), 0.8 watts (sleep), 0.05 watt (Manual-Off), 0.05 (Auto-off/Manual-on), 0.06 watt (Auto-Off/Wake on LAN)
Print cartridges
Number of print cartridges
4 (1 each black, cyan, magenta, yellow)
Replacement cartridges
HP 207A Black LaserJet Toner Cartridge (1,350 yield) W2210A; HP 207A Cyan LaserJet Toner Cartridge (1,250 yield) W2211A; HP 207A Yellow LaserJet Toner Cartridge (1,250 yield) W2212A; HP 207A Magenta LaserJet Toner Cartridge (1,250 yield) W2213A; HP 207X Black LaserJet Toner Cartridge (3,150 yield) W2210X; HP 207X Cyan LaserJet Toner Cartridge (2,450 yield) W2211X; HP 207X Yellow LaserJet Toner Cartridge (2,450 yield) W2212X; HP 207X Magenta LaserJet Toner Cartridge (2,450 yield) W2213X; HP 206A Black LaserJet Toner Cartridge (1,350 yield) W2210A; HP 206A Cyan LaserJet Toner Cartridge (1,250 yield) W2211A; HP 206A Yellow LaserJet Toner Cartridge (1,250 yield) W2212A; HP 206A Magenta LaserJet Toner Cartridge (1,250 yield) W2213A; HP 206X Black LaserJet Toner Cartridge (3,150 yield) W2210X; HP 206X Cyan LaserJet Toner Cartridge (2,450 yield) W2211X; HP 206X Yellow LaserJet Toner Cartridge (2,450 yield) W2212X; HP 206X Magenta LaserJet Toner Cartridge (2,450 yield) W2213X
Replacement cartridges footnote
Replacement 207A cartridge average composite (C/Y/M) declared yield 1,250 and average black yield 1,350 pages; Replacement 207X cartridge average composite (C/Y/M) declared yield 2,450 and average black yield 3,150 pages based on ISO/IEC 19798 and continuous printing. Actual yields vary considerably based on images printed and other factors. For details see http://www.hp.com/go/learnaboutsupplies.
Printing specifications
Print technology
Laser
Duplex printing
Automatic (standard)
Print resolution (best)
Up to 600 x 600 dpi
Maximum print area (metric)
206 x 346 mm
Monthly duty cycle
Up to 40,000 pages
Print languages
HP PCL6; HP PCL5c; HP postscript level 3 emulation; PWG raster; PDF; PCLm; PCLm-S; NativeOffice; URF
Printer smart software features
6.8 cm (2.7 in) colour touchscreen, Automatic 2-sided printing, Ethernet networking, HP ePrint, Apple AirPrint™, Mopria-certified, Google Cloud Print, HP Auto-On/Auto-Off technology, HP Smart App, Smart task shortcuts in HP Smart App, HP JetAdvantage Secure Print
Regulatory specifications
Energy efficiency
EPEAT® Silver
Safety
EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013; IEC 60950-1:2005+A1:2009+A2:2013; EN 60825-1:2014/IEC 60825-1:2014 (Class 1 Laser Product); EN 62479:2010/IEC 62479:2010
Electromagnetic compatibility
CISPR32:2012 & CISPR32:2015/EN55032:2012 & EN55032:2015+AC:2016 - Class B; EN 61000-3-2:2014; EN 61000-3-3:2013; EN 55024:2010+A1:2015
Telecom compliance (fax capability)
Fax Telecom: ES 203 021; Other Telecom approvals as required by individual countries
Scan
Scanner advanced features
HP Scanning software; Scan-to-E-mail, network folder; 50 sheet Automatic Document Feeder (ADF) for unattended scanning of multiple pages; Automatic scan cropping; Scan to Google Drive/Drop box (PC); Scan to FTP(PC); Scan to Microsoft One Drive, Share Point (PC); Save as editable file (text, PDF)
Scan technology
Contact Image Sensor (CIS)
Scan speed (normal)
Up to 26 ppm (black and white); 22 ppm (colour)
Scan speed footnote
Scan speeds measured from ADF. Actual processing speeds may vary depending on scan resolution, network conditions, computer performance, and application software.
Scan resolution, hardware
Up to 300 x 300 dpi (colour and monochrome ADF); Up to 1200 x 1200 dpi (Flatbed)
Levels of grayscale
256
Bit depth
8-bit (mono); 24-bit (color)
Duplex ADF scanning
No
Maximum flatbed scan size (metric)
215.9 x 297 mm
Minimum ADF scan size (metric)
102 x 152 mm
Maximum ADF scan size (metric)
215.9 x 355.6 mm
Twain version
Version 1.9 (Legacy OS); Version 2.1 (Windows 7 or higher)
Security
Security management
Embedded Web Server: password-protection, secure browsing via SSL/TLS; Network: enable/disable network ports and features, SNMPv1 community password change; HP ePrint: HTTPS with certificate validation, HTTP Basic Access Authentication; Firewall and ACL; SNMPv3
System requirements
Minimum system requirements for Windows
Windows® 10, 8.1, 8, 7: 32-bit or 64-bit, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8. Windows Vista®: (32-bit only), 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8. Windows® XP SP3 or higher (32-bit only): any Intel® Pentium® II, Celeron® or 233 MHz compatible processor, 850 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8. Windows Server support is provided via the command line installer and supports Win Server 2008 R2 and higher
Minimum System Requirements for Macintosh
Apple® macOS Sierra (v10.12), macOS High Sierra (v10.13), macOS Mojave (v10.14), macOS Catalina(v10.15), 200 MB available hard disk space, Internet required for download, USB
Compatible Network Operating Systems
Windows® 10, 8, 7: 32/64-bit, 2 GB available hard disk space, Internet connection, USB port, Internet Explorer; 2 GB available hard disk space, Internet connection, USB port, Internet Explorer 8; any Intel® Pentium® II, Celeron® or 233 MHz compatible processor, 850 MB available hard disk space, Internet connection, USB port, Internet Explorer 8; Windows Server support is provided via the command line installer and supports Win Server 2008 R2 and higher; Apple® macOS Sierra (v10.12), macOS High Sierra (v10.13), macOS Mojave (v10.14), macOS Catalina(v10.15), 200 MB available hard disk space, Internet required for download, USB; Linux: for more information see https://developers.hp.com/hp-linux-imaging-and-printing; Unix: for more information see http://www.hp.com.
Operating system (supported note)
Compatible Operating Systems are not supported with INBOX software, but downloadable from online; Full solution software available only for Windows 7 and newer; Windows Server OS install driver only; Windows RT OS for Tablets (32/64-bit) uses a simplified HP print driver built into the RT OS; Linux systems use in-OS HPLIP software
One-year unit exchange warranty. Warranty and support options vary by product, country and local legal requirements. Go to http://www.hp.com/support to learn about HP award winning service and support options in your region.
