    Windows 11 Upgrade Guide
HP ENVY - 13-aq1004tx Product Specifications
8BE41PA
Intel® Core™ i7-10510U (1.8 GHz base frequency, up to 4.9 GHz base with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® Integrated SoC
16 GB DDR4-2400 SDRAM (onboard)
512 GB PCIe® NVMe™ M.2 SSD
13.3" diagonal FHD IPS BrightView micro-edge WLED-backlit touch screen (1920 x 1080)
Intel® Wireless-AC 9560 Wi-Fi 5 (2x2) and Bluetooth® 5 Combo, non-vPro™
1 microSD media card reader
1 USB 3.1 Gen 1 Type-C™ (5 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.2, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 headphone/microphone combo
30.7 x 21.15 x 1.47 cm
Starting at 1.17 kg
65 W AC power adapter
4-cell, 53 Wh Li-ion polymer
Video Playback Battery life
Up to 18 hours and 15 minutes
Bang & Olufsen, quad speakers, HP Audio Boost
HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP Command Center; HP PC Hardware Diagnostics Windows
Pre-installed software
Alexa; iQiyi
