    Fix Windows 10 Update Issues
    Are you working from home?
HP Notebook - 17-ca1023ur Product Specifications
8PN71EA
AMD Ryzen™ 3 3200U with Radeon™ Vega 3 Graphics (2.6 GHz base clock, up to 3.5 GHz max boost clock, 5 MB cache, 2 cores)
AMD Integrated SoC
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
AMD Radeon™ Vega 3 Graphics
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
DVD-Writer
43.9 cm (17.3") diagonal HD+ SVA anti-glare WLED-backlit (1600 x 900)
Realtek RTL8723DE 802.11b/g/n (1x1) and Bluetooth® 4.2 combo
2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 USB 2.0 Type-A (Data Transfer Only); 1 RJ-45; 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo
41.48 x 27.22 x 2.45 cm
2.56 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 8 hours
Video Playback Battery life
Up to 6 hours
HP TrueVision HD Camera with integrated digital microphone
Dual speakers
FreeDOS
