    We are upgrading our website
    Fix Windows 10 Update Issues
HP Notebook - 15-db1108ng Product Specifications
9CS19EA
AMD Ryzen™ 5 3500U with Radeon™ Vega 8 Graphics (2.1 GHz base clock, up to 3.7 GHz max boost clock, 6 MB cache, 4 cores)
AMD Integrated SoC
16 GB DDR4-2400 SDRAM (2 x 8 GB)
Video graphics
  • AMD Radeon™ Vega 8 Graphics
  • Integrated
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
DVD-Writer
39.6 cm (15.6") diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 USB 2.0 Type-A (Data Transfer Only); 1 RJ-45; 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo
37.6 x 24.6 x 2.25 cm
1.8 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 8 hours and 45 minutes
Video Playback Battery life
Up to 7 hours and 15 minutes
HP Webcam with integrated digital microphone
Dual speakers
FreeDOS 1.2
