    Microsoft Support for Windows 7 ended on Jan 14, 2020
    - HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
    - If your computer is not compatible for upgrade to Windows 10, we can help to find the perfect computer for you. Check our Weekly deals!
OMEN by HP 17-cb0010nt Product Specifications
8UL83EA
Intel® Core™ i7-9750H (2.6 GHz base frequency, up to 4.5 GHz base with Intel® Turbo Boost Technology, 12 MB cache, 6 cores)
Intel® HM370
16 GB DDR4-2666 SDRAM (2 x 8 GB)
Video graphics
  • Intel® UHD Graphics 630
  • Discrete
  • NVIDIA® GeForce RTX™ 2070 (8 GB GDDR6 dedicated)
  • 512 GB PCIe® NVMe™ M.2 SSD
  • 1 TB 7200 rpm SATA
Optical drive
Optical drive not included
43.9 cm (17.3") diagonal FHD 144 Hz IPS anti-glare WLED-backlit (1920 x 1080)
1 USB 3.1 Gen 2 Type-C™ with Thunderbolt™ 3 (40 Gb/s signaling rate, DisplayPort™ 1.4, HP Sleep and Charge); 3 USB 3.1 Gen 1 Type-A; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo; 1 microphone; 1 AC smart pin; 1 Mini DisplayPort™
40.5 x 29.5 x 2.7 cm
Starting at 2.97 kg
230 W AC power adapter
4-cell, 70 Wh Li-ion polymer
B&O; dual speakers; HP Audio Boost; Omen Audio Control Support DTS:X® Ultra
FreeDOS 1.2
