    Fix Windows 10 Update Issues
HP Pavilion x360 - 14-dh1350ng Product Specifications
8UP84EA
Intel® Core™ i5-10210U (1.6 GHz base frequency, up to 4.2 GHz base with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® Integrated SoC
16 GB DDR4-2666 SDRAM (1 x 16 GB)
Video graphics
  • Intel® UHD Graphics
  • Integrated
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
35.6 cm (14") diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass, 250 nits, 45% NTSC (1920 x 1080)
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4; 1 headphone/microphone combo
32.4 x 22.29 x 2.05 cm
1.58 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 13 hours and 15 minutes
Video Playback Battery life
Up to 11 hours and 15 minutes
B&O; Dual speakers; HP Audio Boost 1.0
Alexa; HP 3D DriveGuard; HP Audio Switch; HP CoolSense; HP JumpStart; HP Support Assistant
Pre-installed software
Netflix (30-day free trial offer)
