    Fix Windows 10 Update Issues
HP Pavilion Gaming - 15-ec0155ng Product Specifications
9HH44EA
AMD Ryzen™ 5 3550H with Radeon™ Vega 8 Graphics (2.1 GHz base clock, up to 3.7 GHz max boost clock, 6 MB cache, 4 cores)
AMD Integrated SoC
16 GB DDR4-2400 SDRAM (2 x 8 GB)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS anti-glare micro-edge WLED-backlit, 250 nits, 45% NTSC (1920 x 1080)
Realtek Wi-Fi 5 (2x2) and Bluetooth® 5 combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 1 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 USB 2.0 Type-A (HP Sleep and Charge); 1 AC smart pin; 1 HDMI 2.0; 1 headphone/microphone combo; 1 RJ-45
36 x 25.7 x 2.35 cm
2.25 kg
150 W Smart AC power adapter
3-cell, 52.5 Wh Li-ion
Battery life mixed usage
Up to 11 hours and 15 minutes
Video Playback Battery life
Up to 10 hours
HP TrueVision HD Camera with integrated dual array digital microphone
B&O; Dual speakers; HP Audio Boost 1.0
FreeDOS 1.2
