    Fix HP Printer issue on macOS
HP ProDesk 480 G5 Microtower PC - Components
Standard configuration features
Features may vary depending on the model. For support assistance and to learn more about the hardware and software installed on the computer model, run the HP Support Assistant utility.
Figure : HP ProDesk 480 G5 MT
Front panel components
Drive configuration may vary by model. Some models have a bezel blank covering the optical drive bay.
Figure : Identifying the front panel components
(1)
Slim optical drive (optional)
(5)
USB port with HP Sleep and Charge
(2)
Dual-state power button
(6)
USB port
(3)
Hard drive activity light
(7)
USB SuperSpeed ports (2)*
(4)
Audio-out (headphone)/Audio-in (microphone) combo jackAudio-out (headphone)/Audio-in (microphone) combo jack
(8)
Memory card reader
*This port connects a USB device, provides high-speed data transfer, and even when the computer is off, charges products such as a cell phone, camera, activity tracker, or smartwatch.
When a device is plugged into the combo jack, a dialog box is displayed. Select the type of device that is connected.
Rear panel components
Figure : Identifying the rear panel components on a non-vPro computer system
(1)
Audio-out jack for power audio devices
(6)
Audio-in jack
(2)
DisplayPort monitor connectors (2)
(7)
RJ-45 (network) jack
(3)
Optional port
(8)
Serial port (select products only)
(4)
USB ports with Wake from S4/S5 (2)
(9)
Power cord connector
(5)
An optional second serial port and an optional parallel port are available from HP.
If using a USB keyboard, HP recommends connecting the keyboard to one of the USB 2.0 ports with the Wake from S4/S5 feature. The Wake from S4/S5 feature is also supported on the PS/2 connectors if enabled in BIOS F10 Setup.
When a graphics card is installed in one of the system board slots, the video connectors on the graphics card and the integrated graphics on the system board may be used at the same time. However, for such a configuration, only the display connected to the discrete graphics card will display POST messages.
The system board graphics can be disabled by changing settings in Computer Setup.
