    Fix HP Printer issue on macOS
HP EliteDesk 800 G5 Small Form Factor PC - Components
Standard configuration features
Features may vary depending on the model. For support assistance and to learn more about the hardware and software installed on your computer model, run the HP Support Assistant utility.
This computer model can be used in a tower orientation or a desktop orientation. See .
Figure : Standard configuration with computer, monitor, mouse and keyboard
Front panel components
Drive configuration may vary by model. Some models have a bezel blank covering the slim optical drive bay.
Figure : Identifying the front panel components
1
Slim optical drive (optional)
6
USB port with HP Sleep and Charge
2
SD card reader (optional)
7
Audio-out (headphone) jack
3
USB Type-C charging port
8
Audio-out (headphone)/Audio-in (microphone) combo jack**
4
USB SuperSpeed ports (2)*
9
Hard drive activity light
5
USB port
10
Power button
* This port connects a USB device, provides high-speed data transfer, and even when the computer is off, charges products such as a cell phone, camera, activity tracker, or smartwatch.
** When a device is plugged into the combo jack, a dialog box is displayed. Select the type of device that is connected.
The light on the power button is normally white when the power is on. If it is flashing red, there is a problem with the computer and it is displaying a diagnostic code.
Rear panel components
Figure : Identifying the rear panel components
1
Audio-in jack
6
DisplayPort monitor connectors (2)
2
Serial port (optional)
7
Optional port
3
RJ-45 (network) jack
8
USB ports (2)
4
Power cord connector
9
USB SuperSpeed ports (4)*
5
Audio-out jack for powered audio devices
Your model may have additional optional ports available from HP.
When a graphics card is installed in one of the system board slots, the video connectors on the graphics card and/or the integrated graphics on the system board may be used. The specific graphics card installed and software configuration will determine the behavior.
The system board graphics can be disabled by changing settings in BIOS F10 Setup.
Serial number location
Each computer has a unique serial number and a product ID number that are located on the exterior of the computer. Keep these numbers available for use when contacting customer service for assistance.
Figure : Locating the serial number
