HP Pavilion 15-dq1000 x360 Convertible PC - Illustrated Parts
HP continually improves and changes product parts. For complete and current information on supported parts for your computer, go to http://partsurfer.hp.com, select your country or region, and then follow the on-screen instructions.
Computer major components
Figure : Identifying the computer major components
Computer major components and their descriptions
Item
Component
Spare part number
(1)
Display assembly: The display assembly is spared at the subcomponent level only. For more display assembly spare part information, see Display assembly subcomponents.
(2)
Keyboard/top cover (includes keyboard cable)
For a detailed list of country codes, see Keyboard/top cover.
For use in models with a backlit keyboard:
  • With fingerprint reader; natural silver
L51519-xx1
  • Without fingerprint reader; natural silver
L51520-xx1
  • With fingerprint reader; pale gold
L51521-xx1
  • Without fingerprint reader; pale gold
L51522-xx1
For use in models without a backlit keyboard:
L51362-xx1
L51363-xx1
L51364-xx1
L51365-xx1
(3)
TouchPad (includes bracket)
The TouchPad spare part kit does not include the TouchPad cable. The TouchPad cable is available using spare part number L51341-001.
L51336-001
(4)
TouchPad bracket
included with TouchPad
(5)
Fingerprint reader
The fingerprint reader spare part kit does not include the cable. The cable is available using spare part number L51344-001.
L51113-001
(6)
Power connector cable
L51346-001
(7)
Speakers (include left and right speakers and cable)
L51355-001
(8)
USB board
The USB board spare part kit does not include the cable. The cable is available using spare part number L51345-001.
L51334-001
(9)
Power button
Pale gold
L54140-001
Natural silver
L54139-001
(10)
Power button/audio board
The power button/audio board spare part kit does not include the cable. The cable is available using spare part number L51342-001.
L51333-001
(11)
System board (includes processor)
All system board spare part kits include replacement thermal material.
All system boards use the following part numbers:
xxxxxx-001: Non-Windows operating systems
xxxxxx-601: Windows operating system
For use in models with discrete graphics memory:
  • Intel Core i7-8565U processor and 4 GB Radeon 535 graphics memory
L50975-xx1
  • Intel Core i5-8265U processor and 2 GB Radeon 535 graphics memory
L50974-xx1
For use in models with UMA graphics memory:
L50973-xx1
L50972-xx1
  • Intel Core i3-8145U processor
L50971-xx1
Thermal pad, for use in models with discrete graphics memory (not illustrated)
L21302-001
Heat sink (includes replacement thermal material)
(12)
L51348-001
(13)
L51347-001
(14)
Fan
L51349-001
(15)
Solid-state drive (M.2)
512 GB, PCIe
L51361-001
256 GB, PCIe
L51360-001
128 GB, SATA-3, TLC
L51359-001
16 GB, PCIe (Optane Memory Module)
L55350-001
(16)
WLAN module
Realtek RTL8822BE 802.11ac 2 × 2 Wi-Fi + Bluetooth 4.2
924813-855
Realtek RTL8821CE 802.11ac 1 × 1 Wi-Fi + Bluetooth 4.2
L17365-005
Intel Wireless-AC 9560 802.11ac 2 × 2 Wi-Fi + Bluetooth 5
L22634-005
(17)
Memory cover
L51104-001
(18)
Memory module (DDR4)
8 GB
937236-855
4 GB
L10598-855
(19)
2 TB, 5400 rpm
912487-858
1 TB, 5400 rpm
L30422-007
500 GB, 5400 rpm
778186-007
(20)
Battery (3-cell, 41 Whr)
L11119-857
(21)
Bottom cover
L51338-001
L51339-001
(22)
Rubber Feet Kit
L51354-001
Figure : Identifying the display assembly major components
Display assembly components and their descriptions
Item
Component
Spare part number
(1)
Display panel
FHD
L51357-001
HD
L51358-001
(2)
Display cable
L51771-001
(3)
Touch control board
L51770-001
(4)
Webcam/microphone module (includes double-sided adhesive)
L51337-001
(5)
WLAN antenna
L51326-001
(6)
Webcam cable
L51340-001
(7)
Display Hinge Kit (includes left and right display hinges)
For use in models with an FHD display panel
L51819-001
For use in models with an HD display panel
L51331-001
(8)
Hinge cover
L51820-001
L51332-001
(9)
Display enclosure
  • Natural silver
L51327-001
  • Pale gold
L51328-001
  • Natural silver
L51329-001
  • Pale gold
L51330-001
Mass storage devices
Figure : Identifying the mass storage device components
Mass storage devices and their descriptions
Item
Component
Spare part number
(1)
Hard drive cover
L51350-001
(2)
2 TB, 5400 rpm
912487-858
1 TB, 5400 rpm
L30422-007
500 GB, 5400 rpm
778186-007
(3)
Hard drive cable
L51343-001
(4)
Solid-state drive module foil cover
L51352-001
(5)
512 GB, PCIe
L51361-001
256 GB, PCIe
L51360-001
128 GB, SATA-3, TLC
L51359-001
L55350-001
Cables
Figure : Identifying the cables
Cables and their descriptions
Item
Component
Spare part number
(1)
TouchPad cable
L51341-001
(2)
Hard drive cable
L51343-001
(3)
USB board cable
L51345-001
(4)
Power button/audio board cable
L51342-001
Fingerprint reader cable (not illustrated)
L51344-001
Miscellaneous parts
Miscellaneous parts and their descriptions
Component
Spare part number
65 W AC adapter (non-PFC, S-3P, 4.5 mm)
710412-001
65 W AC adapter (non-PFC, S-3P, 4.5 mm) for use in Argentina
710340-850
45 W HP Smart AC adapter (non-PFC, RC, 4.5 mm, non-slim)
741727-001
45 W HP Smart AC adapter (non-PFC, RC, 4.5 mm) for use in Argentina
741553-852
Power cord, (C5, 1.0 m)
For use in Denmark
L19360-001
For use in Europe
L19361-001
For use in Israel
L19362-001
For use in Italy
L19364-001
For use in North America
L19367-001
For use in South Africa
L19369-001
For use in Switzerland
L19370-001
For use in the United Kingdom
L19373-001
Miscellaneous kit (includes heat sink Mylar, heat sink gasket, and WLAN module gasket, WLAN Mylar, fingerprint reader tape, and memory cover and heat sink conductive tape)
L51353-001
Stylus, active pen
910942-001
Pen tip
L04536-001
Adapter, USB-C to USB-A
833960-001
HP USB External DVD-RW Drive
747080-001
HP HDMI-to-VGA adapter
701943-001
HP USB-to-Gigabit RJ-45 adapter
829941-001
HP USB-C-to-RJ-45 adapter
855560-001
Screw Kit
L51356-001
