Your computer features top-rated components. This chapter provides details about your components, where they're located, and how they work.
Component
(1)
Optical drive (select products only)
Depending on your computer model, reads an optical disc or reads and writes to an optical disc.
(2)
Optical drive eject button (select products only)
Releases the optical drive disc tray.
(3)
Audio-out (headphone)/Audio-in (microphone) combo jack
Connects optional powered stereo speakers, headphones, earbuds, a headset, or a television audio cable. Also connects an optional headset microphone. This jack does not support optional standalone microphones.
warning: note: |
(4)
HDMI port
Connects an optional video or audio device, such as a high-definition television, any compatible digital or audio component, or a high-speed High Definition Multimedia Interface (HDMI) device.
(5)
Dual-Mode DisplayPort
Connects an optional digital display device, such as a high-performance monitor or projector.
(6)
USB Type-C power connector and Thunderbolt port with HP Sleep and Charge
Connects an AC adapter that has a USB Type-C connector, supplying power to the computer and, if needed, charging the computer battery.
– and –
Connects and charges most USB devices that have a Type-C connector, such as a cell phone, camera, activity tracker, or smartwatch, and provides high-speed data transfer.
– and –
Connects a display device that has a USB Type-C connector, providing DisplayPort output.
note: note: |
(7)
Power connector
Connects an AC adapter.
(8)
Battery light
When AC power is connected:
When AC power is disconnected (battery not charging):
Component
(1)
Security cable slot
Attaches an optional security cable to the computer.
note: |
(2)
RJ-45 (network) jack/status lights
Connects a network cable.
(3)
USB SuperSpeed port with HP Sleep and Charge
Connects a USB device, provides high-speed data transfer, and even when the computer is off, charges most products such as a cell phone, camera, activity tracker, or smartwatch.
(4)
USB SuperSpeed ports (2)
Connects a USB device, such as a cell phone, camera, activity tracker, or smartwatch, and provides high-speed data transfer.
(5)
Memory card reader
Reads optional memory cards that store, manage, share, or access information.
To insert a card:
To remove a card:
(6)
Smart card reader
Supports optional smart cards.
note:Refer to the illustration that most closely matches your computer.
Component
(1)
WLAN antennas*
Send and receive wireless signals to communicate with wireless local area networks (WLANs).
(2)
WWAN antennas*
Send and receive wireless signals to communicate with wireless wide area networks (WWANs).
(3)
Internal microphones
Record sound.
(4)
Camera light(s)
On: One or more cameras are in use.
(5)
Camera(s)
Allow(s) you to video chat, record video, and record still images.
note: |
*The antennas are not visible from the outside of the computer. For optimal transmission, keep the areas immediately around the antennas free from obstructions.
For wireless regulatory notices, see the section of the Regulatory, Safety, and Environmental Notices that applies to your country or region.
To access this guide:
‒ or –
Component
(1)
Pointing stick
Moves the pointer on the screen.
(2)
Left pointing stick button
Functions like the left button on an external mouse.
(3)
Center pointing stick button
Functions like the center button on an external mouse.
(4)
TouchPad zone
Reads your finger gestures to move the pointer or activate items on the screen.
(5)
(6)
Left TouchPad button
(7)
Right TouchPad button
Functions like the right button on an external mouse.
(8)
Near Field Communications (NFC) tapping area and antenna*
Allows you to wirelessly share information when you tap it with an NFC-enabled device.
(9)
HP DreamColor sensor (select products only)
A colorimeter that brings integrated color calibration to your display. This built-in measurement instrument provides the ability to recalibrate a DreamColor color preset without the use of an external measurement instrument. To select a color preset or launch the calibration tool, select the HP DreamColor icon in the Windows taskbar. Make a selection from the menu and follow the on-screen instructions.
note: |
(10)
Right pointing stick button
*The antenna is not visible from the outside of the computer. For optimal transmission, keep the area immediately around the antenna free from obstructions.
‒ or –
Component
(1)
Power light
(2)
Caps lock light
On: Caps lock is on, which switches the key input to all capital letters.
(3)
Fn lock light
On: The fn key is locked. For more information, see Hot keys (select products only).
(4)
Mute light
(5)
Microphone mute light
(6)
Wireless light
On: An integrated wireless device, such as a wireless local area network (WLAN) device and/or a Bluetooth® device, is on.
note: |
(7)
Sharing or presenting light
On: Sharing is on.
(8)
Call answer light
On: Call answer is on.
(9)
Call end light
On: Call end is on.
(10)
Num lk light
On: Num lock is on.
Component
(1)
Power button
caution: If the computer has stopped responding and shutdown procedures are ineffective, press and hold the power button for at least 5 seconds to turn off the computer.
To learn more about your power settings, see your power options.
(2)
Speakers
Produce sound.
(3)
Fingerprint reader (select products only)
Allows a fingerprint logon to Windows, instead of a password logon.
Component
(1)
esc key
Displays system information when pressed in combination with the fn key.
(2)
fn key
Executes frequently used system functions when pressed in combination with another key. Such key combinations are called hot keys.
(3)
Windows key
Opens the Start menu.
note: |
(4)
Action keys
Execute frequently used system functions.
See Action keys.
(5)
num lk key
Turns the embedded numeric keypad on and off when pressed in combination with the fn key.
– or –
Turns the embedded numeric keypad on and off.
– or –
Alternates between the navigational and numeric functions on the integrated numeric keypad.
(6)
Integrated numeric keypad
A separate keypad to the right of the alphabet keyboard. When num lk is pressed, the integrated keypad can be used like an external numeric keypad.
note: |
Icon
Helps prevent side-angle viewing from onlookers. If needed, decrease or increase brightness for well-lit or darker environments. Press the key again to turn off the privacy screen.
note: |
Decreases the screen brightness incrementally as long as you hold down the key.
Increases the screen brightness incrementally as long as you hold down the key.
Turns the keyboard backlight off or on.
note: |
Plays the previous track of an audio CD or the previous section of a DVD or a Blu-ray Disc (BD).
Starts, pauses, or resumes playback of an audio CD, a DVD, or a BD.
Plays the next track of an audio CD or the next section of a DVD or a BD.
Stops audio or video playback of a CD, a DVD, or a BD.
Decreases speaker volume incrementally while you hold down the key.
Increases speaker volume incrementally while you hold down the key.
Mutes the microphone.
Mutes or restores speaker sound.
Turns the wireless feature on or off.
note: |
Turns the TouchPad and TouchPad light on and off.
Switches the screen image among display devices connected to the system. For example, if a monitor is connected to the computer, repeatedly pressing the key alternates the screen image from computer display to monitor display to simultaneous display on both the computer and the monitor.
Initiates Sleep, which saves your information in system memory. The display and other system components turn off and power is conserved. To exit Sleep, briefly press the power button.
caution: |
Provides quick access to your Skype for Business calendar.
note: |
Turns the screen sharing function on or off.
note: |
note: |
note: |
note:The action key feature is enabled at the factory. You can disable this feature by pressing and holding the fn key and the left shift key. The fn lock light will turn on. After you have disabled the action key feature, you can still perform each function by pressing the fn key in combination with the appropriate action key.
Key
C
Turns on scroll lock.
E
Turns on the insert function.
R
Breaks the operation.
S
Sends a programing query.
W
Pauses the operation.
Component
(1)
Vent
Enables airflow to cool internal components.
note: |
(2)
Service door release latch with lock screw
Releases the service door.
Component
Internal microphones (2)
Record sound.
Component
Vents
Enable airflow to cool internal components.
note: |
note:Check the following locations for the labels described in this section: the bottom of the computer, inside the battery bay, under the service door, on the back of the display, or on the bottom of a tablet kickstand.
Component
(1)
HP product name
(2)
Model number
(3)
Product ID
(4)
Serial number
(5)
Warranty period
Component
(1)
HP product name
(2)
Product ID
(3)
Serial number
(4)
Warranty period
