    Fix HP Printer issue on macOS
HP Elitedesk 705 G4 Small Form Factor PC - Illustrated Parts
Computer major components
Figure : Identifying system parts
Item
(1)
System board (includes replacement thermal material)
For use in models with A10, A8, A6 processors
For use in models with Ryzen PRO processors
(2)
Front bezel
(3)
Dust filter
(4)
Access panel
(5)
Power supply (180 W)
(6)
Heat sink (includes replacement thermal material)
(7)
Fan
(8)
Processor
A10/A8/A6 processors use a different system board than Ryzen processors.
AMD A10-9700
AMD A8-9600
AMD A6-9500
AMD Ryzen 5 PRO 2400G
AMD Ryzen 3 PRO 2200G
(9)
Memory modules (UDIMM, PC4-2666,NECC)
16-GB
8-GB
4-GB
(10)
Speaker
(11)
Hood sensor
(12)
WLAN modules
Intel 3168 802.11 AC 1x1 with Bluetooth 4.0 (Brazil)
Intel 7265 802.11AC 2x2 with Bluetooth M.2 Combo Card non-vPro (Brazil)
Intel 9260 802.11 AC 2x2 +Bluetooth 5 PCIe non-vPro
Realtek 802.11 AC 1x1 with Bluetooth 4.2 LE M.2 PCIe
Realtek 802.11 AC 2x2 with Bluetooth 4.2 LE M.2 PCIe
(13)
AMD Radeon R7 430 2 GB FH PCIe x16 G5 graphics card (select models only)
(14)
Serial+PS/2 port (select models only)
(15)
Antenna cover
(16)
Bezel blank for optical drive slot
(17)
Optical drive latch
Option boards:
HDMI option board
DisplayPort option board
VGA option board
USB Type-C option board
Parallel port, PCIe card
2nd serial port
Card reader assembly
Stand
Power cord
Optical drive bezel
HP USB-C to USB-A Hub
Fan duct
Cables and adapters
Figure : Cables illustrated
Item
(1)
SATA drive power cable
(2)
SATA data cable, 5.7 inch, 2 straight endsd
SATA data cable, 7.5 inch, 2 straight ends
DVI cable, 1.8 m
Internal wireless antennas
Antenna cover
Adapters
DisplayPort to HDMI 2.0
DisplayPort to VGA
DisplayPort to DVI
USB to serial
USB-C to USB 3.0
USB 3.1 Type-C to DisplayPort
Drives
Hard drives (3.5-inch)
2 TB, 7200 rpm
2 TB, 5400 rpm
1 TB, 5400 rpm, hybrid SSD drive, 9.5 mm
1 TB, 7200 rpm, 9.5 mm
1 TB, 7200 rpm
500 GB, 5400 rpm, hybrid SSD drive, 7 mm
500 GB, 7200 rpm hard drive, self-encrypting (SED), Opal 2, 7 mm
500 GB, 7200 rpm, 7 mm
500 GB, 7200 rpm
500 GB, 7200 rpm hard drive, FIPS, 7 mm
Solid-state drives (2.5-inch, SATA, TLC)
512-GB
512-GB, self-encrypting (SED), Opal 2
512-GB, FIPS 140-2
256-GB
256-GB, self-encrypting (SED), Opal 2
256-GB, FIPS 140-2
Solid-state drives (2280, NVMe, M.2)
1-TB, PCIe, TLC
512-GB, PCIe, TLC
512-GB, PCIe
512-GB, self-encrypting (SED), TLC
256-GB, PCIe, TLC
256-GB, PCIe, self-encrypting (SED), TLC
128-GB, PCIe, TLC
128-GB, PCIe
Optical drives, 9.5 mm
BD Blu-ray writer drive
DVD±RW drive
DVD-ROM drive
Mouse and keyboards
Mouse
USB, healthcare, wired
USB, antimicrobial
USB/PS2 Washable
USB, Hardened
USB, optical
PS/2, optical
USB, laser
HP USB Premium
USB/PS2 washable
Keyboards
Washable, USB PS2
USB, unbranded
USB
USB, essential
Conferencing
USB, slim
Wireless, with mouse
USB, slim, smart card
Antimicrobial
USB, slim, gray
USB, collaboration
Wireless, collaboration
USB, wired, healthcare
Premium, wireless
USB, Katydid
