    Fix HP Printer issue on macOS
HP 14-cf0000 Laptop PC - Illustrated Parts
Computer major components
HP continually improves and changes product parts. For complete and current information on supported parts for your computer, go to http://partsurfer.hp.com, select your country or region, and then follow the on-screen instructions.
Figure : Identifying the computer major components
Item
Component
Spare part number
(1)
Display assembly (14 inch)
Displays are only spared at the subcomponent level. For display assembly spare part information, see Display assembly subcomponents.
(2)
Hinge cover
For hinge cover spare part information, see Display assembly subcomponents.
Natural silver
L24474-001
Pale gold
L24471-001
Snow flake white
L24472-001
Tranquil pink
L24473-001
(3)
Top cover/keyboard (includes TouchPad and TouchPad top mylar; does not include TouchPad board or TouchPad click board)
For a detailed list of keyboard country codes, see Top cover/keyboard.
Ash silver, not backlit
L24818-xx1
Ash silver, backlit
L24817-xx1
Snow flake white, backlit
L24819-xx1
Snow flake white, not backlit
L24820-xx1
(4)
TouchPad board cable
L23184-001
(5)
TouchPad board
L24484-001
(6)
The TouchPad click board cable is available using spare part number L24485-001.
L24486-001
(7)
Power connector
L23188-001
(8)
Hard drive (does not include bracket)
1-TB, 5400-rpm, 7 mm
762990-005
500-GB, 5400-rpm, 7 mm
778186-005
(9)
Hard drive cable
L23187-001
(10)
Hard drive bracket
L24490-001
(11)
Battery, 3 cell, 41 Whr, 3.6 Ah Li-ion
L11119-855
(12)
USB board
L24483-001
USB board cable (not illustrated)
L23186-001
(13)
eMMC board (use for 2nd solid-state drive installation)
L23397-001
(14)
Solid-state drive bracket, not shown
L24488-001
Solid-state drive board
L24487-001
(15)
Solid-state drive
PCIe:
  • 512 GB
L25984-001
  • 256 GB
L25983-001
SATA-3, TLC:
  • 256 GB
L25982-001
  • 128 GB
L25981-001
Optane memory module, 16 GB
L34406-001
(16)
Speakers
L24489-001
(17)
System board hook
L23206-001
(18)
System board (includes replacement thermal materials)
All system boards use the following part numbers:
xxxxxx-001: non-Windows operating system
xxxxxx-601: Windows operating system
For use in models with discrete graphics:
  • Intel Core i3-7020U processor and 2 GB of dedicated video memory
L24453-xxx
  • Intel Core i5-8250U processor and 2 GB of dedicated video memory
L24454-xxx
  • Intel Core i5-8265U processor and 2 GB of dedicated video memory
L38210-xxx
  • Intel Core i7-8550U processor and 2 GB of dedicated video memory
L24455-xxx
  • Intel Core i7-8550U processor and 4 GB of dedicated video memory
L24456-xxx
  • Intel Core i7-8565U processor and 2 GB of dedicated video memory
L38211-xxx
For use in models with UMA graphics:
L38212-xxx
L24460-xxx
  • Intel Core i3-8130U processor
L33910-xxx
  • Intel Core i3-7100U processor
L41568-xxx
L24459-xxx
  • Intel Pentium N5000 processor
L24461-xxx
  • Intel Pentium N5000 processor with 64 GB eMMC
L24462-xxx
  • Intel Celeron N4000 processor
L24457-xxx
  • Intel Celeron N4000 processor with 64 GB eMMC
L24458-xxx
(19)
WLAN
Dual antenna:
  • Intel Dual band wireless-AC 3168 802.11AC 1×1 WiFi + BT 4.2 Combo Adaptor (non-vPro)
863934-855
  • Realtek RTL8822BE 802.11 ac 2×2 WiFi + BT 4.2 Combo Adapter (MU-MIMO supported)
924813-855
Single antenna:
  • Realtek RTL8821CE 802.11 ac 1×1 WiFi + BT 4.2 Combo Adapter (MU-MIMO supported)
L17365-005
  • Realtek RTL8723DE 802.11 bgn 1×1 WiFi + BT 4.2 Combo Adapter
L21480-005
  • Intel Dual Band Wireless-AC 9461 802.11 AC 1×1 WiFi + Bluetooth 5 Combo Adapter (non-vPro) (MU-MIMO supported)
L25889-005
(20)
Memory module
4 GB
862397-859
8 GB
862398-855
(21)
Fan, for discrete systems
L23189-001
Fan insert, plastic placeholder for UMA fanless systems (not shown)
L31017-001
(22)
Heat sink assembly, discrete, (includes replacement thermal materials)
L23192-001
(23)
Heat sink assembly, UMA (includes replacement thermal materials)
L23191-001
(24)
Heat sink assembly, for fanless systems (includes replacement thermal materials)
L23190-001
(25)
Rubber Feet (includes front and rear feet)
Natural silver
L24482-001
Pale gold
L24479-001
Snow flake white
L24480-001
Tranquil pink
L24481-001
(26)
Bottom cover
Natural silver
L24478-001
Pale gold
L24475-001
Snow flake white
L24476-001
Tranquil pink
L24477-001
Figure : Identifying the display assembly subcomponents
Item
Component
Spare part number
(1)
Hinge cover
Natural silver
L24474-001
Pale gold
L24471-001
Snow flake white
L24472-001
Tranquil pink
L24473-001
(2)
Display bezel
L24465-001
(3)
Raw display panel (14 inch)
FHD, anti-glare, WLED UWVA
L25977-001
FHD, BrightView, WLED UWVA
L25978-001
HD, anti-glare, WLED SVA
L25979-001
HD, BrightView, WLED SVA
L25980-001
(4)
Hinges (left and right)
L24470-001
(5)
Webcam/microphone module
L23237-001
(6)
Display cable
HD display
L24492-001
FHD display
L24493-001
(7)
Antennas
Dual
L24640-001
Single
L29012-001
(8)
Display enclosure
Natural silver
L24469-001
Pale gold
L24466-001
Snow flake white
L24467-001
Tranquil pink
L24468-001
Miscellaneous parts
Component
Spare part number
Adhesive tape kit
L24491-001
HP Smart AC adapter
45 W, RC 4.5 mm, NPFC, non-slim
741727-001
45 W, NPFC, SB 4.5 RA - Argentina
741553-852
65 W, NPFC, S-3P 4.5 mm
710412-001
65 W, NPFC, RC 4.5 mm, EM
913691-850
65 W, NPFC, SB 4.5 RA - Argentina
710340-850
Power cord (3-pin, black, 1.0-m) for use in:
For use in Argentina
L19357-001
For use in Australia
L19358-001
For use in Denmark
L19360-001
For use in Europe
L19361-001
For use in India
L19363-001
For use in Israel
L19362-001
For use in Italy
L19364-001
For use in Japan
L19365-001
For use in North America
L19367-001
For use in the People’s Republic of China
L19368-001
For use in South America
L19369-001
For use in South Korea
L19366-001
For use in Switzerland
L19370-001
For use in Thailand
L19371-001
For use in Taiwan
L19372-001
For use in the United Kingdom
L19373-001
HP HDMI-to-VGA adapter
701943-001
Screw Kit
L24494-001
