HP Notebook 15s-fq1002tu Product Specifications
8LA69PA
Intel® Core™ i7-1065G7 (1.3 GHz base frequency, up to 3.9 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Video graphics
  • Intel® Iris® Plus Graphics
  • Integrated
512 GB PCIe® NVMe™ M.2 SSD
15.6" diagonal FHD SVA anti-glare micro-edge WLED-backlit (1920 x 1080)
802.11ac (1x1) Wi-Fi® and Bluetooth® 4.2 combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI 1.4b; 1 headphone/microphone combo
35.85 x 24.2 x 1.8 cm
Starting at 1.74 kg
45 W Smart AC adapter
3-cell, 41 Wh Li-ion
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers
HP Audio Switch; HP Documentation; HP ePrint; HP e-Service; HP JumpStart; HP Recovery Manager; HP Support Assistant; HP Connection Optimizer
Pre-installed software
Netflix
