    Windows 11 Upgrade Guide
HP P22h G4 FHD Monitor Product Specifications
7UZ36AA
Display size
21.5"
Display type
IPS
Panel active area(cms)
47.6 x 26.77 cm
Brightness
250 cd/m²
Pixel Pitch
0.247 mm
Input connector
1 DisplayPort™ 1.2 in (with HDCP support); 1 HDMI 1.4 (with HDCP support); 1 VGA
Viewing angle
178° horizontal; 178° vertical
Scan range (horizontal)
Up to 86 kHz
Scan range (vertical)
Up to 75 Hz
Recommended resolution
1920 x 1080 (FHD)
Aspect ratio
16:9
Static contrast ratio;Dynamic contrast ratio
1000:1 static; 8000000:1 dynamic
Response time
5 ms gray to gray
Tilt
Tilt: -5 to +23°
Power supply
Input voltage 100 to 240 VAC
Dimensions
49.73 x 4.59 x 30.11 cm
4.14 kg
What's in the box
What's in the box
AMS: AC Power Cord (1.8 m) 5.9 ft, HDMI Cable (1.8 m) 5.9 ft, DP Cable (1.8 m) 5.9 ft
LA: AC Power Cord (1.8 m) 5.9 ft, HDMI Cable (1.8 m) 5.9 ft, DP Cable (1.8 m) 5.9 ft
APJ (exclude Japan): AC Power Cord (1.8 m) 5.9 ft, VGA Cable (1.8 m) 5.9 ft, HDMI Cable (1.8 m) 5.9 ft APJ Japan: AC Power Cord (1.8 m) 5.9 ft, VGA Cable (1.8 m) 5.9 ft, HDMI Cable (1.8 m) 5.9 ft, DP Cable (1.8 m) 5.9 ft
EMEA: AC Power Cord (1.8 m) 5.9 ft, VGA Cable (1.8 m) 5.9 ft, HDMI Cable (1.8 m) 5.9 ft
