    Microsoft Support for Windows 7 ended on Jan 14, 2020
    - HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
    - If your computer is not compatible for upgrade to Windows 10, we can help to find the perfect computer for you. Check our Weekly deals!
HP ENVY - 13-aq1048tx Product Specifications
8TN44PA
Intel® Core™ i5-10210U (1.6 GHz base frequency, up to 4.2 GHz base with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
8 GB DDR4-2400 SDRAM (onboard)
1 TB PCIe® NVMe™ M.2 SSD
13.3" diagonal FHD IPS BrightView micro-edge WLED-backlit (1920 x 1080)
1 microSD media card reader
1 USB 3.1 Gen 1 Type-C™ (5 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.2, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 headphone/microphone combo
30.7 x 21.15 x 1.47 cm
Starting at 1.17 kg
65 W AC power adapter
4-cell, 53 Wh Li-ion polymer
Bang & Olufsen, quad speakers, HP Audio Boost
HP Audio Switch; HP Documentation; HP e-Service; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP Command Center; HP PC Hardware Diagnostics Windows
Pre-installed software
Alexa; iQiyi
