HP Chromebook x360 - 12b-ca0500na Product Specifications
8RS78EA
Intel® Celeron® N4000 (1.1 GHz base frequency, up to 2.6 GHz burst frequency, 4 MB cache, 2 cores)
Intel® Integrated SoC
4 GB LPDDR4-2400 SDRAM (onboard)
Video graphics
  • Intel® UHD Graphics 600
  • Integrated
64 GB eMMC
Optical drive
Optical drive not included
30.5 cm (12") diagonal HD+ IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1366 x 912)
1 microSD media card reader
2 USB 3.1 Gen 1 Type-C™ (5 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.2); 1 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 headphone/microphone combo
27.2 x 21.6 x 1.73 cm
1.35 kg
45 W USB Type-C™ power adapter
2-cell, 40.31 Wh Li-ion polymer
Battery life mixed usage
Up to 13 hours and 15 minutes
B&O; Dual speakers
Chrome OS™
