    We are upgrading our website
    Fix Windows 10 Update Issues
OMEN by HP 15-dc1083ur Product Specifications
8XC66EA
Intel® Core™ i5-9300H (2.4 GHz base frequency, up to 4.1 GHz base with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
Intel® HM370
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
1 USB 3.1 Gen 2 Type-C™ with Thunderbolt™ 3 (40 Gb/s signaling rate, DisplayPort™ 1.4, HP Sleep and Charge); 3 USB 3.1 Gen 1 Type-A; 1 RJ-45; 1 headphone/microphone combo; 1 microphone; 1 AC smart pin; 1 Mini DisplayPort™
36 x 26.3 x 2.6 cm
2.41 kg
150 W Smart AC power adapter
3-cell, 52 Wh Li-ion polymer
Battery life mixed usage
Up to 6 hours and 15 minutes
Video Playback Battery life
Up to 4 hours and 30 minutes
Bang & Olufsen, dual speakers, HP Audio Boost, DTS Headphone:X™ support
OMEN Command Center; HP 3D DriveGuard; HP Audio Switch; HP JumpStart
