    We are upgrading our website
    Microsoft Support for Windows 7 ended on Jan 14, 2020
    - HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
    - If your computer is not compatible for upgrade to Windows 10, we can help to find the perfect computer for you. Check our Weekly deals!
HP Notebook - 15-rb079ur Product Specifications
8KH75EA
AMD Dual-Core A4-9120 APU (2.2 GHz base frequency, up to 2.5 GHz burst frequency, 1 MB cache)
4 GB DDR4-1866 SDRAM (1 x 4 GB)
Video graphics
AMD Radeon™ R3 Graphics
256 GB M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal HD display
802.11b/g/n (1x1) Wi-Fi® and Bluetooth® 4.0 combo
2 USB 3.1 Gen 1 (Data transfer only); 1 USB 2.0; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
38 x 25.38 x 2.38 cm
1.91 kg
45 W AC power adapter
3-cell, 31 Wh Li-ion
Battery life mixed usage
Up to 11 hours
Video Playback Battery life
Up to 7 hours and 30 minutes
HP Webcam with integrated digital microphone
Dual speakers
FreeDOS 1.2
