    Microsoft Support for Windows 7 ended on Jan 14, 2020
    - HP recommends that you begin the process of upgrading to Windows 10 if your computer has been tested by HP. For more information, click here.
    - If your computer is not compatible for upgrade to Windows 10, we can help to find the perfect computer for you. Check our Weekly deals!
HP Gaming Pavilion - 15-dk0037nq Product Specifications
8PQ85EA
Intel® Core™ i7-9750H (2.6 GHz base frequency, up to 4.5 GHz base with Intel® Turbo Boost Technology, 12 MB cache, 6 cores)
Intel® HM370
16 GB DDR4-2666 SDRAM (2 x 8 GB)
256 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD IPS anti-glare micro-edge WLED-backlit (1920 x 1080)
1 USB 3.1 Gen 2 Type-C™ (10 Gb/s signaling rate, Power Delivery 3.0, DisplayPort™ 1.4, HP Sleep and Charge); 1 USB 3.1 Gen 1 Type-A (HP Sleep and Charge); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 HDMI; 1 AC smart pin; 1 RJ-45; 1 headphone/microphone combo
36 x 25.6 x 2.34 cm
2.28 kg
200 W Smart AC power adapter
3-cell, 52.5 Wh Li-ion
Battery life mixed usage
Up to 8 hours and 30 minutes
Video Playback Battery life
Up to 8 hours
FreeDOS 1.2
