    Coronavirus (COVID-19) Impact
    We are experiencing longer than expected wait times to reach an agent. Please use the resources here on our HP Support website to answer your questions and troubleshoot any issues you may be experiencing.  Try our Virtual Agent and Diagnostic Tools for faster service.
    Are you working from home?
HP Pavilion Gaming - 15-ec0006nq Product Specifications
8PU38EA
AMD Ryzen™ 7 3750H with Radeon™ RX Vega 10 Graphics (2.3 GHz base clock, up to 4 GHz max boost clock, 6 MB cache, 4 cores)
AMD Integrated SoC
8 GB DDR4-2400 SDRAM (2 x 4 GB)
512 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal FHD SVA anti-glare micro-edge WLED-backlit, 220 nits, 45% NTSC (1920 x 1080)
Realtek Wi-Fi 5 (2x2) and Bluetooth® 5 combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 1 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 USB 2.0 Type-A (HP Sleep and Charge); 1 AC smart pin; 1 HDMI 2.0; 1 headphone/microphone combo; 1 RJ-45
36 x 25.7 x 2.35 cm
2.25 kg
150 W Smart AC power adapter
3-cell, 52.5 Wh Li-ion
Battery life mixed usage
Up to 11 hours and 15 minutes
Video Playback Battery life
Up to 10 hours
HP TrueVision HD Camera with integrated dual array digital microphone
B&O; Dual speakers; HP Audio Boost 1.0
FreeDOS 1.2
