    Windows 11 Upgrade Guide
HP PCs - Set Up and Use HP Sure Admin
This document is for the HP Elite Dragonfly and HP Sure Admin app.
The HP Sure Admin app allows local and remote access to device firmware settings by replacing the BIOS password.
Step 1: Download the HP MIK plug-in
Download the HP Manageability Integration Kit (MIK) plug-in from HP.
The HP MIK plug-in includes the HP Sure Admin plug-in.
  1. Click the SoftPaq link next to HP Manageability Integration Kit (MIK).
  2. Follow the on-screen prompts to download and install the HP MIK plug-in.
  3. Complete any security provisioning settings, and then enable Enhanced BIOS Authenticate Mode from the HP Sure Admin plug-in.
Step 2: Create and export a key
To unlock the BIOS with your mobile phone, create a key using the HP Sure Admin plug-in.
  1. In Windows, search for and open Microsoft System Center Configuration Manager (SCCM) or HP Enhanced BIOS Configuration Utility (BCU).
  2. Navigate to and open HP Manageability Integration Kit.
  3. Open HP Sure Admin, and then select the option to create a key.
  4. Type a Name and Passphrase for your key.
  5. Export the key locally or to an Azure AD Group OneDrive.
    • Local computer: Click Browse, and then choose where you want to export the key.
    • Azure AD Group OneDrive: Click Azure AD Login, log in to your account, and then select your group name from the drop-down list. Type the name of the OneDrive folder that you want to export the key to.
  6. Click Create Key, and then click Next.
  7. On the summary page, review the information, and then click Save Policy.
  8. Email the key to your IT administrator.
    Send the QR code in its original size. The application cannot correctly read the code if it is smaller than 800 x 600 ppi in size.
Step 3: Unlock the BIOS
Request the QR code from your IT administrator to unlock the BIOS using the HP Sure Admin app.
  1. Request the QR code from your IT administrator.
  2. On your mobile device, download and open the HP Sure Admin app from the Google Play Store (in English) or Apple App Store (in English).
  3. If you do not have an Azure account, open the QR code on your mobile device, and then share it to the HP Sure Admin app.
  4. On the Enrollment screen, type the passphrase and Azure email address, if necessary.
  5. On the Key Details screen, tap Back, and then tap Scan QR Code.
  6. Tap Scan the BIOS QR Code, and then log in to your Azure account, if necessary.
    The PIN displays on the Your PIN screen.
  7. Type the PIN into the BIOS Enter Response Code text box.
Refer to these frequently asked questions for more information about using the HP Sure Admin app.
